quartusII internal error
fanwel
Full Member level 3
Hi everyone,
I compile a code in QuartusII and during the last task (EDA Netlist Writer) this error occur:
Internal Error: Sub-system: WSC, File: /quartus/neto/wsc/wsc_port.cpp, Line: 514
m_port_info.num_of_dimensions() == 1
Stack Trace:
0x251D8 : WSC_PORT::bus_member_index + 0x88 (NETO_WSC)
End-trace
Quartus II Version 8.1 Build 163 10/28/2008 SJ Web Edition
It's this error occur because of my QuartusII cannot support the compilation? Can anyone help me please..:sad:
Many thanks
internal errors like that need to be reported to altera. There is not alot we can do to help.
you are using an old version, why don't you download the latest version and see if it solves your problem, I'm sure that you will get more enhancements too in the new version, Quartus II is currently in version 11
Alex
Reactions: fanwel
    fanwel
As said, the problem may be solved in a recent version. I understand, that the error is observed while writing an optional EDA netlist. In other words, the compilation itself is O.K.?
My observation is, that unexpected compiler behaviour is often invoked by dubious design constructs that slip through the front end code check.
Thanks everyone. I appreciate your helps.
