Quartus Project from DE2 board to DE1
nizdom
Member level 2
Hi guys! I want to ask something. I found a project with all the verilog codes and sof but the project is for a DE2 board and I wanted to run the project in a DE1 board. What changes should I do in the project? Please help me. thanks.
TrickyDicky
Advanced Member level 5
It will depend what peripherals are in use. The DE1 lacks some features of the DE2 so if it uses these obviously it cannot be ported.
if you are using the same things, then you need to change the target device and the pinout. Also, note that the DE1 has a smaller device - how full is the DE2 device?
