shaiko
Advanced Member level 5
Hello,
I've been trying to synthesize a design with no success.
Quartus (Prime 16.0) fails with the following error message:
The error points to the label marked in red below.Quartus Error (12051): Project too complex: hierarchy path is too long
-- This is a design of a 2d_convolution filter.
-- So no fabric logic (outside the DSP block) is used for the filter calculations.
-- The design is parameterized by defining a KERNEL_SIZE and bits per pixel.
-- KERNEL_SIZE must be an odd number >= 3.
-- Example 1: KERNEL_SIZE = 3. The pixel in the center (P4) will be replaced with a new value.
-- P0 P1 P2
-- P3 P4 P5
-- P6 P7 P8
-- NEW_P4 = P0*C0 + P1*C1 + ... + P8*C8
-- Example 2: KERNEL_SIZE = 5. The pixel in the center (P4) will be replaced with a new value.
-- P0 P1 P2 P3 P4
-- P5 P6 P7 P8 P9
-- P10 P11 P12 P13 P14
-- P15 P16 P17 P18 P19
-- P20 P21 P22 P23 P24
-- NEW_P12 = P0*C0 + P1*C1 ... P24*C24
-- The value of the coefficients (C0, C1, etc...) are internal to the DSP blocks.
-- With every clock, a box of pixels arrive. The number of pixels in a box = KERNEL_SIZE * KERNEL_SIZE.
library ieee ;
use ieee.std_logic_1164.all ;
use ieee.numeric_std.all ;
use ieee.math_real.all ;
library work ;
use work.package_definitions_arrays.all ;
LIBRARY altera_mf; USE altera_mf.altera_mf_components.all;
--LIBRARY altera_lnsim;
--USE altera_lnsim.altera_lnsim_components.all;
entity convolution is
generic
BITS_PER_PIXEL : positive := 18 ;
KERNEL_SIZE : positive := 3
port
IN_CLOCK : in std_logic ; -- Global clock.
IN_GLOBAL_RESET : in std_logic ; -- Asynchronous Reset.
IN_LOCAL_RESET : in std_logic ; -- Synchronous Reset.
IN_ENABLE : in std_logic ; -- Indicates that IN_BOX is valid.
IN_BOX : in generic_1d_slv_array ( 0 to KERNEL_SIZE * KERNEL_SIZE - 1 ) ( BITS_PER_PIXEL - 1 downto 0 ) ; -- The input data is a box of adjacent pixels ( each array element is a pixel ). The "area" of the box is the number of pixels and equals "KERNEL_SIZE * KERNEL_SIZE".
OUT_RESULT : out std_logic_vector ( BITS_PER_PIXEL - 1 downto 0 )
end entity ;
architecture rtl_convolution of convolution is
constant pixels_per_box : positive := KERNEL_SIZE * KERNEL_SIZE ;
signal registered_box : generic_1d_1d_slv_array ( 0 to pixels_per_box - 1 ) ( 0 to pixels_per_box - 1 ) ( BITS_PER_PIXEL - 1 downto 0 ) ;
signal input_to_dsp_multiply : generic_1d_slv_array ( 0 to pixels_per_box - 1 ) ( BITS_PER_PIXEL - 1 downto 0 ) ;
signal input_to_dsp_add : generic_1d_slv_array ( 0 to pixels_per_box - 1 ) ( BITS_PER_PIXEL - 1 downto 0 ) ;
signal output_from_dsp : generic_1d_slv_array ( 0 to pixels_per_box - 1 ) ( BITS_PER_PIXEL - 1 downto 0 ) ;
component ALTERA_MULT_ADD is -- generated by Quartus
port (
result : out std_logic_vector(17 downto 0); -- result.result
dataa_0 : in std_logic_vector(17 downto 0) := (others => '0'); -- dataa_0.dataa_0
datab_0 : in std_logic_vector(17 downto 0) := (others => '0'); -- datab_0.datab_0
clock0 : in std_logic := '0'; -- clock0.clock0
ena0 : in std_logic := '0'; -- ena0.ena0
aclr0 : in std_logic := '0'; -- aclr0.aclr0
chainin : in std_logic_vector(17 downto 0) := (others => '0') -- chainin.chainin
end component ALTERA_MULT_ADD;
begin
-- "registered_box" is a array in which each element is a box.
-- Our goal is to create delayed copies of IN_BOX.
-- The number of copies equals KERNEL_SIZE * KERNEL_SIZE - 1.
-- For example if KERNEL_SIZE = 3. We create 8 delayed copies.
registered_box ( 0 ) <= IN_BOX ;
create_delayed_copies_of_box : process ( IN_CLOCK , IN_GLOBAL_RESET ) is
begin
if IN_GLOBAL_RESET = '1' then
registered_box ( 1 to pixels_per_box - 1 ) <= ( others => ( others => ( others => '0' ) ) ) ;
elsif rising_edge ( IN_CLOCK ) then
for index in 0 to pixels_per_box - 2
loop
registered_box ( index + 1 ) <= registered_box ( index ) ;
end loop ;
end if ;
end process create_delayed_copies_of_box ;
-- From the delayed copies, we choose the required pixels ( not all pixels will be used ).
-- To do this we define "input_to_dsp_multiply".
-- The number of elements in "input_to_dsp_multiply" equals the number of pixels per box.
-- We map the pixels of "registered_box" into the correct location in "input_to_dsp_multiply" such that the pixel delayed the highest number of times will be connected to the last DSP block.
-- Here is an example for a KERNEL_SIZE = 3
-- input_to_dsp_multiply ( 0 ) <= registered_box ( 0 ) ( 0 ) ; -- The pixel that hasn't been delayed will be connected to the first.
-- input_to_dsp_multiply ( 1 ) <= registered_box ( 1 ) ( 1 ) ;
-- input_to_dsp_multiply ( 2 ) <= registered_box ( 2 ) ( 2 ) ;
-- input_to_dsp_multiply ( 3 ) <= registered_box ( 3 ) ( 3 ) ;
-- input_to_dsp_multiply ( 4 ) <= registered_box ( 4 ) ( 4 ) ;
-- input_to_dsp_multiply ( 5 ) <= registered_box ( 5 ) ( 5 ) ;
-- input_to_dsp_multiply ( 6 ) <= registered_box ( 6 ) ( 6 ) ;
-- input_to_dsp_multiply ( 7 ) <= registered_box ( 7 ) ( 7 ) ;
-- input_to_dsp_multiply ( 8 ) <= registered_box ( 8 ) ( 8 ) ; -- The pixel that has been delayed the highest number of times will be connected to the last DSP block.
[COLOR="#FF0000"]connecting_pixels_to_dsp[/COLOR] : for index in 0 to pixels_per_box - 1
generate
altera_mult_add_component : altera_mult_add
PORT MAP
aclr0 => IN_GLOBAL_RESET ,
chainin => input_to_dsp_add ( index ) ,
clock0 => IN_CLOCK ,
ena0 => IN_ENABLE ,
dataa_0 => input_to_dsp_multiply ( index ) ,
datab_0 => ( others => '1' ) ,
result => output_from_dsp ( index )
end generate ;
input_to_dsp_add ( 0 ) <= ( others => '0' ) ;
connecting_between_dsp : for index in 0 to pixels_per_box - 2
generate
input_to_dsp_add ( index + 1 ) <= output_from_dsp ( index ) ;
end generate ;
choosing_pixels_to_connect : for index in 0 to pixels_per_box - 1
generate
input_to_dsp_multiply ( index ) <= registered_box ( index ) ( index ) ;
end generate ;
OUT_RESULT <= output_from_dsp ( pixels_per_box - 1 ) ;
end architecture rtl_convolution ;
