quadrifilar helix antenna
chaitalee
Newbie level 3
hello
i m designing quadrifilar helix antenna in hfss for 400 MHz... so pls give me some solution for modelling the structure of quadrifilar helix ... if u have any info regarding ths thn pls share this to me at chaitu.8788@gmail.com
thnking u in advance
elchiquito
Full Member level 5
Have you looked into this paper.
https://w2du.com/r2ch22.pdf
i was designing my own Quadrifilar helical antenna on hfss,but i stopped because of other endeavors.i can provide you the half done quad helix if interested. well the remaining part is the actual challenge in the design.but anyway let me know
Regards
ELchachito
tallface65
Full Member level 6
land of the free
Download the Antenna Design Toolkit from ANSYS. It is an unlicensed product that will create ~40 or so antennas including several variations of quadrifiliar antennas :)
Have Fun
chaitalee
Newbie level 3
hi
if u can send me that file thn pls do it and thnx in advance for that..
regards
-chaitalee
elchiquito
Full Member level 5
hi
regards
-chaitalee
Attached is the file.
Regards
Elchachito
  • Quadrifilar helicoidal.rar
elchiquito
Full Member level 5
Here's another file of Quadrifilar helix at 400MHz.
Hope it helps
Regards
ELchachito
  • Quadrifilarhelix_shorted.rar
vivinviolita
Newbie level 1
hello
i am on way to designing QHA for 2,4GHz antenna. i am using CST 2011..
i would like to ask you how to make design for this antenna.
i had made a monofilar antenna for 2,4 GHz. then feel little bit confuse about changing the pitch angle. and diameter between small loop and large loop
if you like, can you tell me what kind of parameter that i can use to change them.
at least what can i do in "analytical curve" at CST's option..
thank you very much
:D
