PWM using AXI TIMER core in EDK
mano1988
Newbie level 5
Coimbatore, India
Am using SPARTAN6-LX9 FPGA and trying to generate PWM (2 nos) signals from my embedded processor system (microblaze). Also am using Xilinx 13.2-embedded edition.
I found the AXI Timer core in the IP catalog. I have integrated it to my processor and generated a PWM signal using the timer (PWM is generated from the PWM module in the timer by configuring the TCSR & TLR).
Now I want an another PWM signal that is just not(invert) of the first PWM signal. How do I achive it?
Is there any way I could instantiate a NOT gate or simalr function in the microblaze?
Thank You,
Manoj
Not sure how much you are "changing" your embedded system...you could just open the top level of the embedded system RTL and edit the file so you generate the PWM_N = not(PWN); output. If you do this every time you make changes to the embedded system you'll have to reapply the edits. You might want to make a script to do that.
