Adjust the scope on dc input and check the scope output on pin 3 and print the readings on scope i can see the voltage in pic
---------- Post added at 18:28 ---------- Previous post was at 18:26 ----------
Adjust the scope on dc input and check the scope output on pin 3 make sure u using pin 3 for output and print the readings on scope i can see the voltage in pic
most circuits using 4.7k resistors at pin 3 output
You need a chop-rate high enough that the motor winding
inductance prevents current beyond what you expect. At
locked-rotor or starting from zero RPM there will be no back
EMF, and the current may be well greater than running at
some RPM.
That waveform is pretty creepy, indicates to me that you
have no catch-diode. As a result you might be pulling the
collector and thus the base (since its out-looking impedance
is limited by your IC and board base resistor network) more
negative than BVebo rating, likely damaging the device.
Can't do more than speculate, with the V/div and t/div
text turned off on the 'scope.
very gooood now all u need to do is add a resistor that will take out 2 volts and 0.3 amps off the motor thats 7-15 ohms or 2 in4001 series diodes (try adding them series of the emmiter or motor or collector and see what happens.this is the circuit:
when i have a supply voltage higher than 4.5V,my motor consumes its maximum current possible 0.3A
and i can see too that el motor changes its current consumes sometimes and its speed changes too
output 555 for Vcc=6V
OK dont put resistor on emmiter put it in the collectors it should hold 4v and 300ma thats 15 ohm 1.5watt use resistor with diodes in serial so the diodes will take part of the voltage and resistor will be smaller and less wattage
