spoonieluv
Newbie level 2
- Joined
- Mar 28, 2015
- Messages
- 2
- Helped
- 0
- Reputation
- 0
- Reaction score
- 0
- Trophy points
- 1
- Activity points
- 21
Hi all,
I am an electrical engineer and feel I should know this, but I for the life of me still cant quite get this concept.
I understand conceptually the idea behind a pull up or a pull down, in that we want the IC to read a high state, by default, in the case of a pull up and low by default in case of pull down. But earlier to day an engineer was saying that we needed a lower pull down resistor to drive a pwm from 3 to 5 volts. I still dont get/understand the connection between a pull up/pull down and pwm signal? I get that its ideal to drive a motor using a pwm signal and a resistor could be used as an impedance to drive the pwm, but i still dont get the use of resistor in pwm to pull it "up" or "down"? an example, links or clarifications would be much appreciated. thanks
