mmitchell
Can we use a N-Channel MOSFET as a PWM power switch to give divided-down power supply to a component?
The picture shows an example from OnSemi App Note Using MOSFETs in Load Switch Applications. Because VGS needs to be positive (depending on the threshold), there is an additional VGATE and transistor used to control the gate voltage. When ENn is low, Q1 if off and VGATE is applied to N-MOSFET’s gate, making it open.
For our application, the VIN to the N-Channel transistor is only 0.6V. Therefore, if we have GPIO which is much higher than VIN, as shown in the lower part:
Can we directly use GPIO to control voltage of G, thus saving a transistor?
The transistor we choose is Vishay Si2312BDS.
Would it work if I apply PWM signal at the GPIO, so ultimately the load gets a further divided-down (in terms of power) output as compared to the original 0.6V ? Is this a typical use of transistor?
Matt
VIN = 0.6V
GPIO = 1.8V
GPIO = 1.8V
Matt
