PWM generation for TRIAC control through an optocoupler with PIC16F877A
john120
Banned
Full Member level 5
Hello,there can you please help me to generate a pwm signal for controlling a TRIAC which deals with bulb light control and use its duty cycle as the value of Potentiometer connected to the analog input .
please help see the codes and poteus circuits.
PHP:
#include<16f877a.h>
#device ADC = 10         // Need to tell compiler ADC is configured for 10-bit reading
#fuses HS,NOWDT
#use delay(clock=12000000)
#include<stdio.h>
#include<STDLIB.H>
#use standard_io(A)
#use standard_io(B)
#use standard_io(D)
#define PORTB
#DEFINE PORTC
#define PORTA
//byte const digit[]={0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90};
//char display[3];
int value;
//unsigned long volt;
//unsigned int value2;
void main(){
   set_tris_A(0xFF);
   set_tris_B(0X00);
   set_tris_D(0x00);
   output_b(0);
   output_d(0);
   setup_comparator(NC_NC_NC_NC);
   setup_adc(ADC_CLOCK_INTERNAL);
   setup_adc_ports(AN0);
   set_adc_channel(0);
   setup_vref(FALSE);
   setup_ccp1(CCP_PWM);
   setup_timer_2(T2_DIV_BY_1, 25, 1);
    set_pwm1_duty(volt);
   while(TRUE)
      delay_us(100);
      //value=read_adc(); //Not required
      read_adc(ADC_START_ONLY);
      delay_us(100);
      value=read_adc(ADC_READ_ONLY);
      volt=(value*5)/1023;
,the circuit is here
Please help.
  • TRIAC.zip
Triac must use phase angle control rather than PWM, variable delay with respect to mains voltage zero crossing. There are pretty much hard- and software examples at edaboard
can you please guide me on how controlling the triac using that technique you are saying?
I am using PIC16F877A
Thanks.
