PWM and PSOC 1 on Cypress
bianchi77
California
Hello Guys, anyone has experience on developing code for PWM on PSOC 1 ?
thanks
Simply drop a PWM8 or PWM16 user module into an unused digital block and connect the clock and output. The "code" (API) is described in the datasheet. You need to start it using PWM8_Start() and set the pulse width with PWM8_WritePulseWidth(BYTE bPulseWidth).
Sample code is given in the datasheet
/* include the Counter8 API header file  */
#include  "PWM8.h"
/* function prototype */
void GenerateOneThirdDutyCycle(void);
/* Divide by eight function */
    /* set period to eight clocks */
    PWM8_WritePeriod(23);
    /* set pulse width to generate a 33% duty cycle */
    PWM8_WritePulseWidth(7);
    /* ensure interrupt is disabled */
    PWM8_DisableInt();
    /* start the PWM8! */
    PWM8_Start();
Keith
  • PWM8.pdf
#include  "PWM8.h"
    PWM8_DisableInt();
    PWM8_Start();
Keith
How can I develope this spec?
Operating Speed (4.8V no load) : 0.131sec / 60 degrees
bianchi77 are you trying to interface Servo motor with PSoC1 using PWM in it?
