Putchar() Getchar()
Pheetuz
Full Member level 3
Brighton
I am having a go at teaching myself C, I am using MicroChips IDE and their C18 compiler for this.
I have tried using the putchar() and getchar() command for a very basic program that displays whatever key you press on the keyboard. The program is a program that I know I have run before on codewarrior IDE but it does not seem to want to work on MPLAB.
Is this because a PIC would not have these functions built into them and as such the compiler wont let me use them ??
When I try to compile the program, it says "Cannot use a function without declaring a function prototype". I was under the assumption that the prototype would be in stdio.h ???
Many thanks.
Pete
maybe you should verify if that assumption is faulty?
these function are used to get the character and to display at monitor screen. micro-controller programming is little bit different. what you wanna do???
to get key and display it; first learn how to interface lcd and keypad with micro-controller, then write the code. putchar() and getchar() does not work in micro-controller programming. {although you have built-in library functions like lcd_out() and get_press_key() in mikroc.}
Ahhh, thanks ... Yeah i thought that might be the case, not realy that bothered about the putchar and getchar commands as such, just learning from a book and was worried that the book might be erronious.
Will have a look at getting another IDE / compiler thats not designed for a microprocessor and have another ***** at it.
Cheers guys.
