Kantanshi
Newbie level 3
I've gotten into the "vape" community and many people are going DIY. I've been checking schematics and it appears there are 2 designs they are using. I'm an amateur with electronics and need some help understanding something. I know the purpose of using a MOFSET in the circuit, they seem to be using the IRLB3034PBF. Most are using 1 in their design. Some people, however, are stacking 2 of them by soldering the leads together. I've never seen this done so there's 2 things I wonder about. First is if this actually helps at all. They say it is to allow higher current. Second is if this actually helps or is it pointless? Also, I've been trying to research MOFSETs and learned about double gates. Would this be a better option and if so, what P/N should I use as a substitute?
