Register Log in
pure sine wave inverter problem
pakkiboy
Member level 1
Jeddah, Saudi Arabia, Saudi Arabia
I have made circuits for pure sine wave inverter. first i have used SG3525 to covert 12v DC to 300 Dc , then i have make full bridge using Ir2101 and Mosfet 3205 , mine main issue when i give output of first crkt ( 300 v DC ) to drain of mosfets in bridge circuit , 300 dc voltage drops to 60 v dc and about 5 A current flow :( any help??
pradeep.g.belchada
Full Member level 6
MUMBAI INDIA
first of all you check the primary converter. disconect the 300vdc to the drain of mosfet. now conect a 100watt 230vac rated bulb on 300vdc
now check the 300vdc if it drops then their is a problem in primary converter
post your schematic & photo here
pradeep.g.belchada
Full Member level 6
MUMBAI INDIA
yes for temporary testing you can conect a 100watt bulb
or if you have a load resistor of 100watt that also be ok
pakkiboy
Member level 1
I have used this circuit ... as feedback is given in it , then why voltage drop to extreme level ?? any help ?
Regards
this is crkt diagram of frst stage i used
http://obrazki.elektroda.pl/4566970400_1379271846.png
