Pulse Width Modulation
Sherif Welsen
Junior Member level 1
Hi all,
Please I wanna you provide me with a code written in ASM for 8051 that perform the Pulse Width Modulation of some date.
Regards.
IanP
Advanced Member level 5
West Coast
Here you will find an example of a code for 8051 on PWM controlled LEDs:
https://www.iguanalabs.com/pwm.htm
There will be scores of other examples but I think this one is one of the simples and most comprehensive desription of PWM using basic 8051 (without built-in PWM block) ..
good luck and rgs ..
Sherif Welsen
Thanks for immediate reply. Could you provide me with another examples.
IanP
West Coast
As you probably know, some of 8051 microcontrollers have a PWM module built in. In this case control of this module is relatively simple.
If you would like to compare more examples on PWM and 8051, do you prefer pure 8051-core (software PWM) or 8051 derivatives with buil-in PWM module (hardware solution) ?
redhat
Egypt
you can find an example of PWM Motor Control in Myke Predko's book which you can download from the forum
Sherif Welsen
IanP said:
... some of 8051 microcontrollers have a PWM module built in ... do you prefer pure 8051-core (software PWM) or 8051 derivatives with buil-in PWM module (hardware solution) ?
I would prefere PURE 8051-core ( software PWM ).
Thanks inadvance.
Added after 4 minutes:
redhat said:
you can find an example of PWM Motor Control in Myke Predko's book which you can download from the forum h**p://
This book deals with PIC MCU. I need to understand it in 8051 MCU.
Regards.
