pulse transformer X isolation transformer
mago
Junior Member level 2
isolating pulse transformer
Are these two names the same thing? A pulse transformer is the same thing as isolation transformer?
Kral
USA
mago,
They are not the same, although a pulse transformer can also be an isolation transformer. An isolation transformer has two electrically isoltaed windings for the purpose of providing a ground (common) reference on the secondary side that is elctrically isolated from the primary. A pulse transformer is a high frequency transformer that is designed with minimum inter-winding an intra-winding capacitance, so that there is minimum ringing on the output when a waveform with sharp rising and/or falling edges is applied.
Regards,
Kral
Reactions: pawan kumar
    mago
    pawan kumar
flatulent
Advanced Member level 5
Middle Earth
Another thing is that the pulse transformer is specified by time domain parameters.
Audio transformers are specified by frequency domain, impedance levels, and power.
Power transformers are specified by voltage and current at each winding as well as the operating frequency.
    mago
saubhik
Full Member level 3
India
Pulse Transformer
It's core is made of Ferrite and
is used for high frequency applications and
the turns ratio is one to many or vice versa
Insulation Transformer
It's core is made of silicon steel and
is used for power frequency applications and
the turns ratio is one to one
pravin_dwaramwar
Nagpur - India
They are not the same, although a pulse transformer is used for electrical isolation betn high power and low power circuits .
Pulse transformer is used for providing triggering to SCRS in power electronic applications.
It comes 1:1( 1 primary, 1 secondary), 1:1:1: (1 primary, 2 secondaries for bridge appllications)
