I have used a 555timer to output a pulsed signal. The amplitude is 4.6V. I am then inputting this signal into a transistor to pulse the LED. However when I do this the amplitude drops to 0.8V. How do stop the amplitude from falling when I put it through the transistor? :?:
I'm guessing that you have the transistor emitter connected to ground and the base connected directly to the 555 (not through a resistor). In that case, as the base voltage is increased it will start to pass current into the base and through to the emitter. This will limit the voltage at the base to 0.6-0.8 volts which is the voltage drop across the base-emitter "equivalent" diode.
Always drive the base through a series resistor.
Susan
