Pulse Current PCB width calculator
penrico
Full Member level 5
Argentina
Hey,
I have a board that have some signals, that will have non repetitive pulses of 8A 20 mSeg long.
The problem, is that my board don't have enoght space to use a 150 mils or more to meet the 8A current in average mode.
Do somebody has a I2t (current vs time) formula for the widht of trace in PCB?. Do somebody has something of information how to calculate the right trace width for a pulse current?
Thanks.
As a conservative estimation, you can put in the copper foil thermal capacity and a permissible overtemperature to calculate an I2t value.
I remember, that Raychem had published some I2t data of PCBs related to fuse dimensioning.
    penrico
If you are in doubt, can you increase the thickness of the copper layers? This normally doesn't take more board space.
Can you just use a thinner track locally, and use a wide enough trace where possible? IMHO you can live safely with less than half of the 150mils for a single 20msec pulse.
Stefaan
From thermnal capacity, I calculate a Δt of 1.4 K for a 75 mils 1oz (35 um) trace. With 15 mils, Δt for a single pulse is below 40 K.
Resistive voltage drop and average power dissipation may be a more serious problem.
