pull up by nmos and pull down by pmos works??
elexian
how pmos works
no problem...
Most important is the grid-source voltage.
If you can ensure this voltage that works perfectly.
The mos cannot know if he are pulling up or down !
bye
dear friend if u use nmos for pull up then Vt(Vgs) will decreased from Vdd but for pmos Vdd transfer to out put .for pull down is is oppose
regards
if you use a nmos for pull up, your output would be VDD-Vth. Likewise, if you use a pmos for pull down, your output would be GND+Vth.
