rickyice
Junior Member level 2
pt timing
Please reference the following for the next group of questions
Startpoint: fifo_rd_pd_reg_16_
(rising edge-triggered flip-flop clocked by my_clock)
Endpoint: we_bank_0_reg_2_
Path Group: my_group
Path Type: max
Point Cap Trans Incr Path
clock my_clock (rise edge) 0.0000 0.0000
clock network delay (ideal) 0.0000 0.0000
fifo_rd_pd_reg_16_/CK (p_SDFFHX4) 0.0000 0.0000 0.0000 r
fifo_rd_pd_reg_16_/Q (p_SDFFHX4) 0.0226 0.0542 0.1166 0.1166 f
obuf_U1904/Y (NAND3BX4) 0.0095 0.0643 0.0915 0.2082 f
obuf_U1903/Y (INVX8) 0.0188 0.0450 0.0385 0.2467 r
obuf_buf_1_add_524_U14/Y (NAND2X4) 0.0088 0.0431 0.0374 0.2841 f
U7015/Y (OAI21X4) 0.0111 0.1008 0.0781 0.3622 r
U22745/Y (AOI21X4) 0.0054 0.0481 0.0294 0.3916 f
obuf_U9743/Y (OAI21X4) 0.0067 0.0772 0.0638 0.4554 r
obuf_buf_1_add_524_U57/Y (XNOR2X4) 0.0098 0.1071 0.0769 0.5323 r
DP_OP_248_5346_8_U51/CO0 (AFCSHCINX2) 0.0037 0.0970 0.1378 0.6702 r
obuf_U9662/Y (MX2X4) 0.0077 0.0382 0.0825 0.7527 r
DP_OP_248_5346_8_U44/S (AFCSHCINX4) 0.0075 0.0462 0.1200 0.8726 f
obuf_U9746/Y (INVX6) 0.0174 0.0463 0.0394 0.9120 r
obuf_U1772/Y (NOR2X4) 0.0113 0.0554 0.0294 0.9414 f
U17999/Y (OA22X4) 0.0058 0.0398 0.1128 1.0542 f
obuf_U1852/Y (NOR2X4) 0.0116 0.0909 0.0686 1.1228 r
U26782/Y (INVX10) 0.0549 0.0558 0.0538 1.1765 f
U7011/Y (OA22X4) 0.0092 0.0465 0.0982 1.2747 f
U27252/Y (CLKNAND2X2) 0.0057 0.0484 0.0402 1.3149 r
U24494/Y (XOR2X3) 0.0058 0.0531 0.0386 1.3536 f
obuf_U3105/Y (NOR2X4) 0.0056 0.0583 0.0497 1.4033 r
obuf_U3097/Y (NAND2X4) 0.0056 0.0341 0.0329 1.4362 f
obuf_U3094/Y (NOR2X4) 0.0053 0.0534 0.0421 1.4784 r
obuf_U1886/Y (AOI21X4) 0.0157 0.0607 0.0580 1.5364 f
obuf_U1861/Y (NOR3X4) 0.0101 0.1561 0.1036 1.6400 r
U24496/Y (INVX4) 0.0073 0.0442 0.0351 1.6751 f
obuf_U1760/Y (OR2X4) 0.0135 0.0378 0.0731 1.7481 f
obuf_U9462/Y (INVX12) 0.0325 0.0428 0.0358 1.7839 r
U17857/Y (OAI211X4) 0.0062 0.0992 0.0506 1.8345 f
U24495/Y (CLKINVX6) 0.0036 0.0334 0.0188 1.8533 r
we_bank_0_reg_2_/D (p_SDFFRHQX4) 0.0334 0.0000 1.8533 r
data arrival time 1.8533
clock my_clock (rise edge) 1.8000 1.8000
clock network delay (ideal) 0.0000 1.8000
we_bank_0_reg_2_/CK (p_SDFFRHQX4) 0.0000 1.8000 r
library setup time -0.0701 1.7299
data required time 1.7299
data arrival time -1.8533
slack (VIOLATED) -0.1234
1. What assumptions can you make about operating conditions from this report?
2. Would this report be useful near the end (tape-out) of a chip? Please explain your answer.
3.What new parameters do you need to know to calculate the timing of the above circuit?
4.Are there new issues that are of concern with the addition of the new gate and input signal? Please describe in detail
Path Type: max
