pt commands help
helloPDworld
Newbie
Newbie level 3
Given a list of nets , is it possible to get physical attributes such as route_length and net delay in snps primetime (say pnr and extraction is done)?
What are the commands/ attribute ?
Thanks
Some AVRs have a mute circuit or a protection relay that prevents the main outputs from working if a fault is detected. Use your multimeter to check the voltage at the speaker relay contacts.
Thanks
I would recommand you to use the following command : list_attributes -application
You will get a list of all possible attributes given by the tool. Maybe route_length is given, or another equivalent attribute.
Note that this command prints a lot of things, redirect the output to a txt file would help you to read clearly.
LaTeX Commands Quick-Menu:
