[SOLVED] PSRR of Error Amplifier
Engineer4ever
Member level 3
Member level 3
I am designing an error amplifier as a part of LDO circuit and I needed to get its PSRR. I placed an AC source as a power supply with a swing=1v and freq=1KHz. When I put DC voltage=3.5v in the AC source, the PSRR graph was completely wrong, it was improving as freq. increases!!!! When I put DC voltage=zero, the graph was right, PSRR value was getting worse as freq. increases.
The question is, is it right to put DC voltage=zero? because I didn't know that and I was just trying different ways to fix the problem and I thought that the DC value of power supply should be kept during this analysis.
Thanks,
NO
It must be in the normal operating DC range. Ripple is assumed to be low impedance source like the DC source, which was not mentioned and may be your issue.
The recommended approach uses both sources in parallel with impedance isolation. Note the AC or RF source must be zero ohms or buffered somehow to prevent loading by any connection. A Spectrum Analyzer or Network Analyzer is required.
Below is an alternative method showing both AC & DC combined into a suitable low Zout buffer.
You should show your test circuit, which is probably somehow wrong. PSRR of an amplifier is defined as the input referred suppression of power supply variation, your test circuit must implement frequency independent gain to visualize the PSRR directly.
PSRR of the complete LDO, including bypass capacitors, isn't necessarily monotonously decreasing versus frequency.
This is the EA circuit. I put an AC source in series with the DC source to represent the ripples of the power supply.
