Register Log in
PSPICE Simulation of a flyback transformer
strape81
Junior Member level 3
Hi everyone,
I have just created a .lib and .olb file of a flyback transformer using the Magnetics Part Editor which is available with orcad (see View attachment trafo4042.zip).
As next step I have made a schematic using this transformer in order to test if it works properly (see flyback_conv.JPG).
I have run a simulation in time domain but the following errors occured, which I cannot understand :
*Analysis directives:
.TRAN 0 1000ns 0
.OPTIONS DIGINITSTATE= 0
.PROBE V(alias(*)) I(alias(*)) W(alias(*)) D(alias(*)) NOISE(alias(*))
.INC "..\SCHEMATIC1.net"
**** INCLUDING SCHEMATIC1.net ****
* source TESTING_TRAFO4042
D_D3 N06013 OUT15V D1N4003
D_D1 N10730 OUT13V ZHCS750/ZTX
X_U1 N00149 N00095 N06013 0 N10730 0 N08144 0 TRAFO4042 PARAMS: NP=24
+ RSP=0.056011 LLP=5.86021E-006 NS1=4 RSS1=0.127423 NS2=4 RSS2=0.00654831 NS3=6
+ RSS3=0.0138977 GAP=0.024055
R_R3 0 OUT19V 1G TC=0,0
V_V2 N00412 0
+PULSE -5 15 0 0 0 10u 20u
R_R4 OUT15V 0 100 TC=0,0
X_M1 N00095 N00412 0 IXFK120N20/IXS
V_V1 N00149 0 127Vdc
C_C3 OUT15V 0 47u
C_C1 OUT13V 0 680u
C_C2 OUT19V 0 680u
D_D2 N08144 OUT19V ZHCS750/ZTX
R_R2 0 OUT13V 1G TC=0,0
**** RESUMING testing_trafo4042.cir ****
.END
ERROR -- Less than 2 connections at node N06013 (The node connected to V_OUT11)
ERROR -- Less than 2 connections at node N10730 (The node connected to V_OUT21)
ERROR -- Less than 2 connections at node N08144 (The node connected to V_OUT31)
ERROR -- Less than 2 connections at node X_U1.V_OUT11
ERROR -- Less than 2 connections at node X_U1.V_OUT21
ERROR -- Less than 2 connections at node X_U1.V_OUT31
ERROR -- Node X_U1.NLS1 is floating
ERROR -- Node X_U1.V_OUT12 is floating
ERROR -- Node X_U1.V_OUT11 is floating
ERROR -- Node X_U1.NLS2 is floating
ERROR -- Node X_U1.V_OUT22 is floating
ERROR -- Node X_U1.V_OUT21 is floating
ERROR -- Node X_U1.NLS3 is floating
ERROR -- Node X_U1.V_OUT32 is floating
ERROR -- Node X_U1.V_OUT31 is floating
Please does anyone have an idea why these errors occur?
For your information:
The pins of the transformer are set to "Passive".
PSPICE Error Guide : View attachment psphlp with error explanations.pdf
FvM
Super Moderator
Staff member
Bochum, Germany
The terminal signal names of the subcircuit don't correspond to the internal used names, e.g. V_OUT11V versus V_OUT11.
* PSpice Model Editor - Version 16.2.0
* Generated by Magnetic Parts Editor on 21.12.2011
* Trafo 4042-T1
.subckt trafo4042 V_IN1 V_IN2
+ V_OUT11V V_OUT12V
+ V_OUT21V V_OUT22V
+ V_OUT31V V_OUT32V
+ PARAMS:
+ Np=24 RSp=0.056011 Llp=5.86021e-006
+ Ns1=4 RSs1=0.127423 Ns2=4 RSs2=0.00654831 Ns3=6 RSs3=0.0138977
+ Gap=0.024055
L_LP NLP V_IN2 {Np}
R_RP NRP NLP {RSp}
L_Leak V_IN1 NRP {Llp}
L_LS1 NLS1 V_OUT12 {Ns1}
R_RS1 NLS1 V_OUT11 {RSs1}
L_LS2 NLS2 V_OUT22 {Ns2}
R_RS2 NLS2 V_OUT21 {RSs2}
L_LS3 NLS3 V_OUT32 {Ns3}
R_RS3 NLS3 V_OUT31 {RSs3}
K_K2 L_LP L_LS1 L_LS2 L_LS3 1.0 core_model_K1
.model core_model_K1 AKO:core_model CORE (GAP={Gap})
.model core_model CORE (LEVEL=3 OD=6.19 ID=0 AREA=0.832 GAP=0.024055 Br=1700 Bm=4500 Hc=0.1875)
.ends trafo4042
