Hi everyone. I'm trying to determine the frequency of a incoming signal at roughly 7KHz. This signal is correctly identified using a scope and is at correct logic levels. I am using the 16bit Tachometer digital block which adds a second interrupt. It is basically a 16 bit timer with the added interrupt. I have a 1MHz input clock which should get me enough resolution for this. The incoming frequency is fed into the capture port on the block. Now I'm having trouble getting a frequency measurement. Here is some of my code.
I am getting the decimal value of 2222 for "diff" which stays consistent with the frequency at 7.3KHz but can't seem to figure out how to get this value in frequency form. I have searched hours for this and haven't gotten much of anywhere. Any help is greatly appreciated.
