ps2 key board voltage issue
raman00084
Full Member level 6
Full Member level 6
i am interfacing ps2 key board in arm lpc1768, the ps2 supply voltage is 5v but lpc1768 is 3.3v how can i connect the interrupt and data pins in lpc1768 should i use any resistor.thank you
regards,
Check the lpc datasheet. Maybe the io is 5V compatible...
Klaus
