ps2 key board data conversion
raman00084
Full Member level 6
Full Member level 6
i have a ps2 key board program that decodes the key press value into ascii. example the return value of the ps2 key board is
ps2_keyvalue= 64
how to convert the ps2_keyvalue to my assigned value for example
ps2_keyvalue = 64 for the 64 i am assigning another value example 10
like this i will be assigning different values for different ascii codes
can i use array for this?
please send some c code for doing the above job i am a beginner in c
Assign an array of char, with the all values you want, and read it with the keyvalue as index. This will work as a lookup table.
