[SOLVED] PS/2 mouse communication issue
akvii
Member level 5
mouse communication
Dear All
I am interfacing ps/2 mouse with pic 18F452....i have sent all the initial commands to mouse ie reset (FF from pic and i get FA,AA and 0 from mouse),then i send remote setting command and I get FA from mouse,then i send enable command and get FA from the device, after that I dont receive any thing from the mouse
I even tried remote mode but when I send read command,I get FA(which I should be) and instead of 3 data packets i get AA
I will be very gratefulu if any one kindly help me out
ps2 mouse communication
here is the code...written in PICBASIC
Device 18F452
XTAL = 20 ' Declaring 20 MHz crystal
' LCD DECLARATION'''''
Declare LCD_TYPE 0
Declare LCD_INTERFACE 4
Declare LCD_LINES 2
Declare LCD_DTPIN PORTB.4
Declare LCD_ENPIN PORTB.3
Declare LCD_RSPIN PORTB.2
ALL_DIGITAL TRUE
Symbol DATA_PIN = PORTB.1 'CONNECT DATA PIN AT PORTB.1
Symbol CLK_PIN = PORTB.0 'CONNECT DATA PIN AT PORTB.0
Dim CNT As DWord
Dim TMP As Word
Dim DATA_SEND As Word
Dim TEMP As Word'Byte
Dim VAR1 As Word
Dim PARITY As Word
Dim I As Word
Dim RECV_BYTE As Word
Dim RECV_BYTE_1 As Word
Dim RECV_BYTE_2 As Word
Dim RECV_BYTE_3 As Word
Dim RECV_BYTE_4 As Word
Dim RECV_BYTE_5 As WordDim j As Byte
Clear ' CLEAR ALL VARIABLES
DelayMS 250
Cls
Print At 1,1,"PS/2 MOUSE "
DelayMS 2000 ' WAIT FOR 2 SECONDS TO STABILZE MOUSE
Cls
AA: DelayMS 10
DATA_SEND=$ff
Print At 1,1,"RESET"
GoSub SEND_BYTE
GoSub RECV_BYTE_FROM_PS2 ' GRAB FIRST BYTE FROM MOUSE
If RECV_BYTE <> $FA Then GoTo AA ' IF FIRST BYTE IS NOT FA, THEN RESET IT AGAIN
GoSub RECV_BYTE_FROM_PS2 ' GRAB SECOND BYTE FROM MOUSE
If RECV_BYTE <> $AA Then GoTo AA ' IF SECOND BYTE IS NOT AA, THEN RESET IT AGAIN
GoSub RECV_BYTE_FROM_PS2' GRAB THIRD BYTE FROM MOUSE
If RECV_BYTE <> $00 Then GoTo AA ' IF THIRD BYTE IS NOT 00, THEN RESET IT AGAIN
Call PRINT_DATA ' PRINT WHAT IS RECEIVED FROM MOUSE
DelayMS 100
' DelayMS 5000
'Cls
' SEND ENABLE COMMAND
cc: DelayMS 10
Print At 1,1,"ENABLE"
DATA_SEND=$F4 ' ENABLE MOUSE
GoSub SEND_BYTE
Print At 2,1,HEX2 RECV_BYTE 'Print WHAT IS RECEIVED FROM MOUSE
If RECV_BYTE <> $FA Then GoTo cc ' IF ITS NOT FA,SEND ENABLE COMMAND AGAIN
DelayMS 1000
Cls
While 1=1
Inc CNT
GG: DelayMS 10
DATA_SEND=$EB ' READ DATA
GoSub SEND_BYTE
'''''HERE I GET FA AA AND 00''''''
DELAYMS 50 ' GET DATA ATFER EVERY 50 MILLI SECONDS
Wend
RECV_BYTE_FROM_PS2:
Input CLK_PIN
Input DATA_PIN
DelayUS 35
While CLK_PIN = 1 And DATA_PIN = 1 : Wend
While DATA_PIN = 1 : Wend
While CLK_PIN = 0 :Wend
For I = 0 To 10
While CLK_PIN =1: Wend
TMP.10 = DATA_PIN
'var1 = tmp.10
TMP=TMP>>1
While CLK_PIN=0 :Wend
Next I
RECV_BYTE=TMP.BYTE0
Return
SEND_BYTE:
Call FIND_PARITY
DATA_SEND.8 = PARITY.0
Output DATA_PIN
Output CLK_PIN
Set DATA_PIN
Set CLK_PIN
DelayUS 40
Clear CLK_PIN
DelayUS 110
Clear DATA_PIN
DelayUS 5
Set CLK_PIN
Input CLK_PIN
TEMP = DATA_SEND
'SENDING DATA AND PARITY BIT
For I = 0 To 8
While CLK_PIN = 1 : Wend ' WAIT TILL CLOCK IS HI
DATA_PIN = TEMP.0 ' TRANSFER DATA TO PORT
TEMP = DATA_SEND >> 1 ' SHIFT RIGHT
While CLK_PIN = 0 : Wend ' WAIT TILL CLOCK IS LOW
Next
DATA_PIN = 1
Input DATA_PIN
While DATA_PIN = 1 : Wend ' WAIT TILL DATA IS HI
Return
PRINT_DATA:
Print At 1,1,HEX2 RECV_BYTE_1," ",HEX2 RECV_BYTE_2," ",HEX2 RECV_BYTE_3," ",HEX2 RECV_BYTE_4,HEX2 RECV_BYTE_5
Print At 2,1,HEX2 RECV_BYTE," ",HEX3 CNT
Return
Re: ps2 mouse communication
I have the same problem . mouse dont give data after setting stream or remote mode. only returns 0xFA. I am using AVR Atmega32:cry:
can someone pls post the code for interfacing optical mouse with pic18f4550???
here is the working code
Device 18F452
Xtal = 20' =FOSC/1000000
Declare LCD_Type 0
Declare LCD_Interface 4
Declare LCD_Lines 2
Declare LCD_DTPin PORTB.4
Declare LCD_ENPin PORTB.3
Declare LCD_RSPin PORTB.2
Dim MILLIMETER As Float
Dim MILLIMETER_1 As Float
Dim INCHES As Float
Dim TOTAL_COUNT As Dword
Dim CNT_2 As Dword
Dim TMP As Word
Dim TMP_1 As Word
Dim DATA_SEND As Byte
Dim TEMP As Word
Dim PARITY As Byte
Dim I As Byte
Dim RECV_BYTE As Byte
Dim RECV_BYTE_1 As Byte
Dim RECV_BYTE_2 As Byte
Dim RECV_BYTE_3 As Byte
Dim ACK_BIT As Byte
Clear
Symbol RBIF= INTCON.0 ' RB4:7 IF
Symbol INT0IF= INTCON.1 '' INT IF
Symbol TMR0IF= INTCON.2 ' TMR0 Overflow Interrupt Flag
Symbol RBIE= INTCON.3 ' B4:B7 IE
Symbol INT0IE= INTCON.4 '' INT IE
Symbol TMR0IE = INTCON.5 ' TMR0 Overflow Interrupt Enable
Symbol PEIE= INTCON.6 ''
Symbol GIE = INTCON.7 '' Global Interrupt Enable
Symbol GIEL= INTCON.6 ' LOW PRIORITY ENABLE
Symbol GIEH = INTCON.7 ' HIGH PRIORITY ENABLE
Symbol CODO =%00000000
Symbol CIDO =%00000010
Symbol CIDI =%00000011
' MICE COMMANDS
Symbol REST =$FF
Symbol Resend =$FE
Symbol DEFAULT =$F6
Symbol Disabl =$F5
Symbol Enbl =$F4
Symbol SetSR =$F3
Symbol ReadTyp =$F2
Symbol SetRem =$F0
Symbol SetWrap =$EE
Symbol ResWrap =$EC
Symbol ReadDat =$EB
Symbol SetStrM =$EA
Symbol StatReq =$E9
Symbol SetRes =$E8
Symbol SetSca21=$E7
Symbol SetSca11=$E6
' MICE BUTTONS
Symbol LButt =1
Symbol MButt =4
Symbol RButt =2
Symbol SFast =25 ' HOW FAST
' Symbol RBPU = INTCON2.7 '0 = PORTB pull-ups are enabled by individual port latch values
' Symbol INTEDG0= INTCON2.6 '1 = Interrupt0 on rising edge
' Symbol INTEDG1= INTCON2.5 '1 = Interrupt1 on rising edge
' Symbol INTEDG2= INTCON2.4 '1 = Interrupt2 on rising edge
' Symbol TMR0IP = INTCON2.2 'TMR0 Overflow Interrupt Priority bit 1=High
' Symbol RBIP = INTCON2.0 'RB Port Change Interrupt Priority bit 1=High
'GIE = 0
MAIN:
DelayMS 250
Cls
Print At 1,1,"Distance Meter"
DelayMS 2000
'Cls
AA: DelayMS 10
DATA_SEND=REST
Print At 2,15,Hex2 DATA_SEND
GoSub SEND_BYTE
RECV_BYTE_1 = RECV_BYTE
RECV_BYTE_2 = RECV_BYTE
RECV_BYTE_3 = RECV_BYTE
If RECV_BYTE <> 0 Then GoTo AA
MM: DelayMS 10
DATA_SEND= $F0 ' SET REMOTE MODE
GoSub SEND_BYTE
'Print At 1,1,HEX2 RECV_BYTE
'If RECV_BYTE <> $FA Then GoTo MM
NN: DelayMS 10
DATA_SEND=$E8
GoSub SEND_BYTE
Print At 1,1,Hex2 RECV_BYTE
If RECV_BYTE <> $FA Then GoTo NN
NNN: DelayMS 10
DATA_SEND=$03
GoSub SEND_BYTE
Print At 2,1,Hex2 RECV_BYTE
If RECV_BYTE <> $FA Then GoTo NNN
Cls
While 1=1
QWERTY:
DATA_SEND=$EB
GoSub SEND_BYTE
If RECV_BYTE_1.0 = 1 Or RECV_BYTE_1.1 = 1 Or RECV_BYTE_1.2 = 1 Then
TOTAL_COUNT = 0
EndIf
If RECV_BYTE_1.4 = 0 Then
TOTAL_COUNT = TOTAL_COUNT + RECV_BYTE_2
EndIf
If RECV_BYTE_1.4 = 1 Then
TOTAL_COUNT = TOTAL_COUNT - ($ff - RECV_BYTE_2)
If TOTAL_COUNT < 1 Then TOTAL_COUNT = 0
EndIf
INCHES = TOTAL_COUNT/800
MILLIMETER_1 = INCHES * 25.4
MILLIMETER = TOTAL_COUNT * 0.03175
Print At 1,1,Dec4 TOTAL_COUNT," ",Dec3 INCHES
Print At 2,1,Dec3 MILLIMETER'," "',DEC2 MILLIMETER_1
DelayMS 10
GoTo QWERTY
Wend
RECV_BYTE_FROM_PS2:
Input CLK_PIN
Input DATA_PIN
For I = 0 To 10
TMP_1.10 = DATA_PIN
TMP_1 = TMP_1 >> 1
Next I
RECV_BYTE=TMP_1.Byte0
TMP_1 = 0
Return
SEND_BYTE:
Call FIND_PARITY
TMP = 0
TEMP = 0
TEMP.Byte0 = DATA_SEND
TEMP.8 = PARITY.0
Output DATA_PIN
Output CLK_PIN
DATA_PIN = 1
CLK_PIN = 1
DelayUS 40
CLK_PIN = 0
DelayUS 110
DATA_PIN = 0
DelayUS 25
CLK_PIN = 1
Input CLK_PIN
For I = 0 To 8
DATA_PIN = TEMP.0
TEMP = TEMP >> 1
Next
DATA_PIN = 1
Input DATA_PIN
Return
FIND_PARITY:
PARITY=0
TMP=DATA_SEND.Byte0
For I=0 To 7
PARITY=PARITY+TMP.0
TMP = TMP >> 1
Next I
PARITY=PARITY // 2
If PARITY =0 Then
PARITY =1
Else
PARITY=0
EndIf
Return
