PROTEUS VSM MPLAB DRIVER
Fragrance
East Of Earth
proteus mplab
hi all
lab center has release the vdm driver for mplab here
is some detial
The PROTEUS VSM MPLAB driver allows Proteus VSM to function as a plug-in debugger for the MPLAB 6 IDE. The driver must be installed on the machine running MPLAB 6, whilst Proteus itself can be installed either on the same machine, or on a different one.
Separate instructions are provided for each way of working:
Using MPLAB and Proteus on a Single Machine
Using MPLAB and Proteus on Two Machines
Please note that you must install MPLAB 6 and Proteus 6.3 SP1 or later in order to use this driver.
To Use Proteus and MPLAB on a Single Machine
1. Load the schematic for the hardware into ISIS.
2. Select the Use Remote Debug Monitor option from the Debug menu.
3. Load the project for the software into MPLAB
4. Select Proteus VSM under Select Tool from the Debugger menu in MPLAB
5. Select Connect from the Debugger menu or click the green circle on the toolbar to initiate a debugging session.
You can now use all the normal features of the MPLAB IDE to debug your code including single step, breakpoints, memory views and so forth. If you need to see what is happening on the schematic, you can use ALT-TAB to flip between MPLAB and Proteus.
Note that there is no need to specify the location of the program file (HEX or COF) on the schematic. MPLAB will load the program into the PIC program memory automatically each time you rebuild the project.
the file is free and download from link given
https://www.labcenter.co.uk/support/files/vdmmplab.exe
