Oct 18, 2005 #1 D donkey41 Full Member level 1 Joined Feb 19, 2002 Messages 99 Helped 2 Reputation 4 Reaction score 1 Trophy points 1,288 Location Pakistan Activity points 949 hello there, I have tested 16F508 µC with proteus without any problem. When I try to simulate 16F88 with COD file, it always gives the following error : [U1] Loading COD file 'J:\pic_tests\16F88_test\16F88_test.COD' FATAL: [U1] Program or EEPROM data has invalid address [2000] for this device. However, it doesn't complain if I use HEX format. Where is the problem and what is the solution ? regards.
Oct 31, 2005 #2 V vitko Junior Member level 3 Joined Dec 29, 2003 Messages 25 Helped 1 Reputation 2 Reaction score 1 Trophy points 1,283 Activity points 226 Remove user ID location code in your source file. For example you can comment this code like below: ;IDLOCS CODE ; ID location data, address is in 16f628a.lkr ; dw 0x0102 ; dw 0x0304
