Proteus Library TSOP component
GrandAlf
Advanced Member level 2
UK
lcd proteus
I am trying to find a 16x1 lcd model for proteus. I understand that these are configured electrically as 8x2. I have been looking at data sheets, but am unable to find what the character addresses are. I am assuming that the first row is 00-07 and second is 40-47, this may be wrong. A typical display of this type would be MDLS 16168. Could anyone help with advice on how to edit the 16x1 model in proteus to 8x2 electrical, or source a new model.
Many thanks
Fragrance
East Of Earth
proteus lcd
hi,
if you mean 1X8 this will in proteus try out this
display then select LM020L
hope this will help also read the lcdalpha help
Reactions: alaa1231
    V
    alaa1231
GrandAlf
UK
sed1335 proteus
Can't get this one to work, what I actually need is single line display of 16 chars, but the ones I am using are electrically configured as 2x8, even though they are single line. This is apparently quite common. I have tried altering the setting of the proteus model, but as I am not sure of each lines start address, I seem to be getting nowhere.
lad
Junior Member level 2
Italy
lcd in proteus
I'm looking for sed1335 proteus model, someone can help me?
Fragrance
East Of Earth
lcd en proteus
HI,
here is the lib called led optical this lib contain 2x16 line lcd display i will see tonight the solution, i told you after testing it, how you edit the properties of the model so it work only as 1x16
ONE THING MORE PLEASE RENAME THE FILE .RAR TO .LIB
ok edit the properties of the model by seleting instent edit mode click on the model and tick in the box edit all properties delete the row two scirpt
and also row two adress now it work as 1x16 lcd
GrandAlf
UK
proteus
Thanks for your help, I will give this one a try when I get back to the office on Monday. I notice the single line one in proteus starts at 0x80 to 0x8f, this is not the same as ones that I use. Data sheets seem to show everything else exept the row addresses.
I was guessing row 1 00-07H
Row 2 40-47H
16x1 physical, 8x2 electrical
Wrong guess I think?
    V
HN
Member level 1
proteus lcd
:wink: I downloaded it.But This file is not opening.
Error:This archive is either in unknown fomat or damaged.
Why... :?:
HN
Member level 1
lcd proteus model
:) O.K. Now.It's opening...
HN
segmex
lcd models
How can i download the file ??? it is not working
Iain
lcd nt7603 proteus
The map for the LCD models in Proteus is configurable for just this reason.
1) Edit the LCD Component on the schematic (Right click on the part and select edit from the context menu).
2) Check the 'Edit All Properties As Text' at the bottom left of the Edit Component Dialogue.
3) In LM020L for example you can then change the RHS of the property {ROW1=80-8F} as required.
Iain.
lts123
Newbie level 2
lcd 3510i for proteus
Maybe it can help me !
kleinwang
Newbie level 1
1x16 lcd second
We are a professional LCD manufacturer in mainland China .We can provide a full range of LCD products ,including character LCD module(from 8*1 to 40*4),graphic LCD module (from 122*32 to 320*240 )and also we can provide customed designed projects for your special requirements ..To know more about us please visit our website at www.htdisplay.com.
HTDisplay (HK) Ltd.
Email: klein_wang@htdisplay.com
www.htdisplay.com
MSN:wangkunpy@hotmail.com
Skype:wangkunlcd
