Proteus and CCS help!!
mindstorm88
Member level 1
Canada
proteus ccs
I guys i'm new to it , and i can't figure out how to use Proteus with CCS C for PIC !!! i want to run a c program for Picdem 2 plus !!
any tutorial somewhere??
Thanks
p.s. yes i did search before asking , if it exist, i missed it !! :)
mindstorm88
Member level 1
Canada
Ok that is the help file that already comes with Proteus !!! so not really help as i already checked it
I just want to know how to use C program as the add source seem to want asm only !!!!
Thanks
Added after 51 minutes:
Ok guys finally found out
Thanks
nomad13
Full Member level 3
Can you show the solution to us?
I'm also interested in using C compiler with proteus.
Thanks
mindstorm88
Member level 1
Canada
I'll try to make it short !!!
First i use CCS compiler through MPlab , when i compile a project it creates many files , hex, lst , etc one of em is a .COF files.
In Proteus you select the PIC and goes to its "edit component", then you select your .COF files as its program file !!!
Then if you've drawn your hardware correctly , it should run !!
Begin with a flashing LED to start with , easier to figure out !!!
pouchito
Full Member level 2
i selected once the ".Hex" and not the ".COF" files and it worked!!
But my original program was written in assembly
benzey
Newbie level 1
let see can it help me or not
thanks
akvii
Member level 5
tutorial file is attached
Kaleborg
Member level 4
Hi
If you are using CCS inside MPLAB you can use Proteus as debbuger.
Go to Debbuger>Select Tool>Proteus VSM
Regards
