Proteous simulation problem
Rins Anto V
Newbie level 3
Newbie level 3
my proteous professional 8 show different simulation result for same hex file.
Attach the code.
what Micro-controller / Micro-processor did you use?
microcontroller is PIC16F877A and compiler is MiKro c, am attaching the circuit diagram pwm1.jpg
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
unsigned short current_duty, old_duty, current_duty1, old_duty1;
void InitMain() {
  ANSEL  = 0;                         // Configure AN pins as digital
  ANSELH = 0;
  C1ON_bit = 0;                       // Disable comparators
  C2ON_bit = 0;
  PORTA = 255;
  TRISA = 255;                        // configure PORTA pins as input
  PORTB = 0;                          // set PORTB to 0
  TRISB = 0;                          // designate PORTB pins as output
  PORTC = 0;                          // set PORTC to 0
  TRISC = 0;                          // designate PORTC pins as output
  PWM1_Init(5000);                    // Initialize PWM1 module at 5KHz
  PWM2_Init(5000);                    // Initialize PWM2 module at 5KHz
void main() {
  InitMain();
  current_duty  = 16;                 // initial value for current_duty
  current_duty1 = 16;                 // initial value for current_duty1
  PWM1_Start();                       // start PWM1
  PWM2_Start();                       // start PWM2
  PWM1_Set_Duty(current_duty);        // Set current duty for PWM1
  PWM2_Set_Duty(current_duty1);       // Set current duty for PWM2
  while (1) {                         // endless loop
    if (RA0_bit) {                    // button on RA0 pressed
      Delay_ms(40);
      current_duty++;                 // increment current_duty
    if (RA1_bit) {                    // button on RA1 pressed
      Delay_ms(40);
      current_duty--;                 // decrement current_duty
    if (RA2_bit) {                    // button on RA2 pressed
      Delay_ms(40);
      current_duty1++;                // increment current_duty1
    if (RA3_bit) {                    // button on RA3 pressed
      Delay_ms(40);
      current_duty1--;                // decrement current_duty1
    Delay_ms(5);                      // slow down change pace a little
Your button circuit is not correct. You are testing for high when a button is pressed, so, the pins should be pulled down using 10k resistors. The button connect between +5V and MCU pin.
