Protel DXP 2004 Fill Pad option...
sadashiv_sm
Member level 3
Mumbai,India
HI...
Is there any option availble in Protel DXP for the PAD FILL OPtion..
i mean there is a option available in Eagle called fill Pad....with this it is really easy to drill in a systematic way....when we Fabricate PCBs at home...
P*otel DXP 2004 Fill Pad option...
hi
Drills in Protel DXP are in another window.
regards
The drills are displayed with an option on the printing configuration. Select "holes" box on the printing configuration.
CD
Re: P*otel DXP 2004 Fill Pad option...
CD
HI
That is all things that I want to say.
regards
Thanks for your valuable response....
I have tried this ......
what u have given is for printing.....and i dont have a laser printer....
still i have a question....that how to make gerber ....which has this option...
i mean the option of fill pad....
generally for single sided pcb i make them at home....and while drilling i face problem of allignment of drills....if the option for Fill pad is available that will be good....
Thanks & Regards
Sadashiv[/i]
For gerber ouput you must have to choose:
File -> Fabrication Outputs -> gerber files
Follow instructions to generate gerber files. Be careful, generate gerber files don't generate drilling files !!!
You must generate drilling files with:
File -> Fabrication Outputs -> NC drills files
CD
Hi, i am agree with upstair. You have to generate drill and gerber file separately.
