propeller display with microchip pic
gigio224
Newbie level 3
propeller display
who can make a small example of as to make this type of display with microcontroller pic
h**p://www.ledcontrol.narod.ru/
my native language is the Spanish and I have translated electronic this text reason why comprencion by my ingles is thanked for badly[/url]
look here:
(it uses 16F84)
good luck
Zed
pic propeller
or I have armed circuits of that type but it wanted to obtain data of something but great in which it is possible even to be drawn like that Coca-Cola says that in fact this not writing but that this unfolding an image in bmp or in format GIF like the following example
propller control pic
I think it's possible to modify the mentoined clock to
drive a lot of RGB leds and you need to attach a CF card or something like that which stores the BMP
(it's much easier than decoding a GIF). And just
display the columns of the BMP on the LEDs with
proper timing.
Zed
12f629 air display
how to control the leds when using handheld stick?
12f629 air text
By using tilt switch or manually press switch.
ir on-off switch pic12f629
check this out:
using PIC12F629 microchip
air display jose pino hex
how pic 12F629 know exact time to light up the led,and whick leds is light up?
microchip pic stick
I think its just a matter of timing and calibration.....
propeller display
sHoEsTRiNG said:
check this out:
Just curious - how is an 8-pin µC controlling 8 LED's?
Nick
how to modify motor for propeller clock
can propeller displays be done , the ANALOG way? without using uControllers??
i would really love to make one, even a simple display will do... :)
can someone post schems?
propeller display bmp
That is a very interesting question. I've never considered
making one without a µC - thanks for the idea! I think this
could be done fairly easily. A clock would be challenging,
but just a display of stored data should be pretty straight
forward. Just thinking out loud here.......
1) The display uses 8 LED's.
2) Store data in a standard EPROM (27C256, etc)
3) Use a buffer between EPROM data lines and LED's
4) A pair of cascaded CD4040 binary ripple counters are
connected to EPROM address lines.
5) The counters are clocked with a 555 timer.
You'd have to do a lot of fine tuning on the motor speed
and 555 frequency. You could use a big EPROM or cascade
many EPROMs/CD4040's for a longer display time.
I think I might give this a try when I have some free time! :)
Nick
12f629 propeller clock
I created the "air display" (a kind of noisemaker that displays messajes). It uses only a 12F629 and drives 7 Leds. You can find the schematic and HEX code @ **broken link removed**. It doesn't use any sensor, it just timming. It have 15 pre-programmed messages. Right now, I'm working to create a new version that uses custom messages.
Jose Pino
como hacer propeller display
Nick C. said:
sHoEsTRiNG said:
check this out:
Nick
He has connected some LEDs in parallel.
josepino air display
Better to say, I think, diodes are in antiparallel positions...Four pins=eight diodes.
standard frequency cd4040
Here are some asnwers:
Nick
Well see the attached link, and look at tip #2:
https://ww1.microchip.com/downloads/en/DeviceDoc/40040b.pdf
I saw some where that they continued the idea and connected even more leds, i cant remember the ratio for number pines to leds.
Well, if you know your start point, and the time that you got to your end point, you can divide that to segments, or degrees. Each degree you will light or turn off the leds, just like a 7 sement that uses leds...
cd4040 data
Nick
dude! can you help me out? idd really love to make one.. for starters , i dunno if youve heard of DIODE rom??? i wanna create just a simple one... got no idea how to..... :) tnx
jose pino propeller clock
hi folks,
in what direction does -normal- propeller clocks rotate?? counter or clocwise???
i got a VCR head motor here but rotates ONLY in one direction.....
air display pic12f
An update.. ive done a -wand- message display... and I had to rotate it clockwise.... RC osc, problem is that sometimes when i push the switch, it wont work.. i mean the LEDs wont light.... and I knw that the SWitch is not the problem.... maybe changing the osc to a crystal would do.. and i need brighter LEDs at the output....
