rain6
Newbie level 3
Master or Slave
HI,
I'm currently doing a project on Speech with Digital Signal Processing, whereby i need to input some of speech signal, and do some processing to eliminate the noise or echo, and output to the speaker. I am using dsPIC 33FJ 256 GP710 and Si3000 codec.
(1) Should i use DCI module with DMA or without DMA?
(2) Which of the component should play the role as Master to generate the Frame synchronisation? dsPIC33F or Si3000?
Thanks
HI,
Thanks
