avins_123
Member level 2
Hello,
I have simulated a transition from Stripline to Microstripline, I have these doubts. The band is S-Band (3-4GHz). The return loss obtained is -26dB and Insertion Loss obtained is -0.5dB.
How to calculate
1) Power( I/P, O/P and P-P powe) of the transition( They say it is calculated from insertion loss i.e, for -0.5dB, it is 1.23watts, Is this right).
2) Bandwidth of the transition( These are transmission lines and not antennas),
I found that BW definition is fh-fl / fc, i.e, fh=3GHz, fl = 4GHz, fc = 3.5GHz, so that means BW is 28.57%, Is this right ?
3) Why is RT Duroid 5880 the best choice for the substrate ?
4) Hos does εr affect the transition, return and insertion loss ?
5) Why is return loss always negative and more and insertion loss positiive and less ?
6) What does -26dB Return loss and 05dB Insertion loss actually mean ?
Please help, I really want to clarify these doubts.
Regards,
Avinash
How to calculate
Regards,
Avinash
