[SOLVED] Progress Bar Display Problem on LCD , please help ??
xpress_embedo
India
I have to make a progress bar on my lcd (16x2), but having some problem
Previously i had made a progress bar based on 16 Values as on lcd we can display 16 characters easily, I had done this successfully
Have a look at this video
https://www.youtube.com/watch?v=5XYMfwnPXtQ
But now i have to create 32 steps on lcd, that's why i use one shaded box to display one value and other to display full.
By this i had created 32 steps on lcd.
But i am not able to display progress bar in negative direction pls help
here is my code
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
163
164
165
166
167
168
169
170
171
172
173
174
175
// LCD module connections
sbit LCD_RS at RC0_bit;
sbit LCD_EN at RC1_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISC0_bit;
sbit LCD_EN_Direction at TRISC1_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// End LCD module connections
unsigned char key;
unsigned char flag;
int counter = 0;
const char Less_Than[] = {1,3,7,15,15,7,3,1};
const char Greater_Than[] = {16,24,28,30,30,28,24,16};
const char Shaded_Block[] = {21,10,21,10,21,10,21,10};
void interrupt(void)
 if(INTCON.RBIE & INTCON.RBIF)
  key = PORTB;
  key = key & 0xC0;
  if(key == 0x40)             //Down key is Pressed
   if(counter > -16)
    counter--;
  else if(key == 0x80)        //Up Key Pressed
   if(counter < 16)
    counter++;
  key = PORTB;
  key = key & 0xC0;
  while(key != 0xC0)
   PORTB = 0xC0;
   key = PORTB;
   key = key & 0xC0;
  flag = 1;
  INTCON.RBIF = 0;
void Display_Value(int value)
 unsigned char ones,tens;
 if(value >= 0)
  Lcd_Chr(1,14,'+');
 else
  value = value * (-1);
  Lcd_Chr(1,14,'-');
 ones = value % 10;
 value = value / 10;
 tens = value % 10;
 ones = ones | 0x30;
 tens = tens | 0x30;
 Lcd_Chr(1,15,tens);
 Lcd_Chr(1,16,ones);
void Progress_Bar(int value)
 unsigned char j;
 if(value == 0)
  Lcd_Chr(2,8,0);
  Lcd_Chr(2,9,1);
 else if(value > 0)
  value = value+16;
  Lcd_Chr(2,8,' ');
  for(j=16;j<value;j++)
   if(j%2 == 0)
    Lcd_Chr(2,j/2+1,2);
   else
    Lcd_Chr(2,j/2+1,0xFF);
  j=j+1;
  for(;j<32;j++)
   if(j%2 == 0)
    Lcd_Chr(2,j/2+1,' ');
   else
 else if(value < 0)
  value = value + 16;
  Lcd_Chr(2,9,' ');
void main()
 unsigned char i;
 counter = 0;
 TRISB |= 0b11110000;
 Lcd_Init();
 Lcd_Cmd(_LCD_CLEAR);
 Lcd_Cmd(_LCD_CURSOR_OFF);
 Delay_ms(10);
 Lcd_Out(1,5,"EDA BOARD");
 Lcd_Out(2,1,"<-PROGRESS-BAR->");
 Delay_ms(1000);
 INTCON.RBIE = 1;
 INTCON.GIE = 1;
 INTCON.PEIE = 1;
 Lcd_Out(1,1,"Progress Bar:");
 Display_Value(counter);
 Progress_Bar(counter);
 Lcd_Cmd(64);          //CGRAM Address
 for(i=0;i<8;i++)
  Lcd_Chr_Cp(Less_Than[i]);
 Lcd_Cmd(_LCD_RETURN_HOME);
 Lcd_Cmd(72);
 for(i=0;i<8;i++)
  Lcd_Chr_Cp(Greater_Than[i]);
 Lcd_Cmd(80);
 for(i=0;i<8;i++)
  Lcd_Chr_Cp(Shaded_Block[i]);
 while(1)
  if(flag != 0)
   flag = 0;
Please help me, i am not able to write code for negative values pls help.
and also is there any method to reduce the flicker on lcd.
to see flicker have a look at this video also.
View attachment Progress Bar Problem.zip
Project Files
View attachment Progress_Bar.zip
Please some one help me
You have to create two custom characters for LCD. One is for one complete LCD character and another for half the character of LCD. First you display the half character on LCD then you display the full charcater. So it will get you 32 steps of Progress bar. each character of LCD takes two values (half and full).
Thanks for your kind reply.
I had solved this problem
