programming using KEIL for ATMEL89Cx2051
blastronics
Member level 3
Between heaven and earth
keil 2051 manual
hello to all...
im using MPLAB for programming PIC microconmtrollers.
Now, im starting to learn how to program atmel AT89CX2051 using keil.
The problem is i dont know where to start.
anybody knows a tutorial for keil using atmel microcontroller?
thanks
blastronics
This site can be a good starting point:
Regards,
IanP
Search in Keil site. There are lot of examples and keil program help itself have lot of material to help you
Best of luck with 51's
Nandhu
Not sure, whether you use evaluation or paid version of Keil, but just in case you use the evaluation version, do not be surprise, when any of your code for *2051 will not be working on real gadget.
The problem is, that the free version places generated code behind the code memory, which is available on these small devices. A long time ago I spent two nights, before I have solved really mysterious behaviour by reading the manual completely.
