I want to design project include microcontroller programmed based on gas leak sensed by gas sensor . Starting at minimum range of 10 PPM(part per million) gas leak measured by the gas sensor,it will send signal to PIC16F887 microcontroller and should be displayed in LCD display. in addition, the microcontroller also will send signal interface with serial port RS 232 to send the signal as message through GSM modem to the authorised person,informing him (there is gas leak). The authorised person can replay by message to the GSM modem and MAX 232 will convert the message as signal received to PIC16F887 microcontroller.in the same time, the microcontroller will acknowledge solenoid valve to shut it off and isolate the leak. i have done this programming code but it give me error when I build the program in the compiler !!
// Lcd pinout settings
sbit LCD_RS at RB0_bit;
sbit LCD_EN at RB1_bit;
sbit LCD_D4 at RB2_bit;
sbit LCD_D5 at RB3_bit;
sbit LCD_D6 at RB4_bit;
sbit LCD_D7 at RB5_bit;
// Pin direction
sbit LCD_RS_Direction at TRISB0_bit;
sbit LCD_EN_Direction at TRISB1_bit;
sbit LCD_D4_Direction at TRISB2_bit;
sbit LCD_D5_Direction at TRISB3_bit;
sbit LCD_D6_Direction at TRISB4_bit;
sbit LCD_D7_Direction at TRISB5_bit;
void Lcd_Init();
void SendMessage();
void CheckGasSensor();
void UpdateLCD();
void SolenoidDisableGas();
//Global sensor status code value
int SENSOR_STATUS_CODE = 0;
//Global gas concentration level
double GAS_CONCENTRATION_LEVEL = 0.0;
void main()
//Setup LCD screen
Lcd_Init();
Lcd_Out(1, 1, "LPG Detector");
Lcd_Cmd(_LCD_CURSOR_OFF);
//Program Run loop
while(1){
//Check for a sensor reading
CheckGasSensor();
//Update the text on the LCD Screen
UpdateLCD();
//Shut off the gas if the gas level is dangerous
if(SENSOR_STATUS_CODE == 2){
//Send a GSM message if there is an error
if(SENSOR_STATUS_CODE != 0){
SendMessage();
//Wait a second between updates
Delay_ms(1000);
void CheckGasSensor(){
//Put the code here to read the sensor
if( (GAS_CONCENTRATION_LEVEL > 5) && (GAS_CONCENTRATION_LEVEL < 10) ){
//Sets the sensor status code to 1 (warning level)
//if the gas is between 5 and 10 ppm
SENSOR_STATUS_CODE = 1;
else if(GAS_CONCENTRATION_LEVEL > 10){
//Sets the sensor status code to 2 (danger level)
//if the gas is above 10 ppm
SENSOR_STATUS_CODE = 2;
else{
//Sets the sensor status code to 0 (okay)
void UpdateLCD(){
//Check if there are no errors
if(SENSOR_STATUS_CODE == 0){
Lcd_Out(2, 1, "Status: Normal ");
else if (SENSOR_STATUS_CODE == 1){
Lcd_Out(2, 1, "Status:Warning! ");
else if (SENSOR_STATUS_CODE == 2){
Lcd_Out(2, 1, "Status:Gas Off ");
//Shut off the Gas
SolenoidDisableGas(){
//Disable the gas by turning on a solenoid
//You can choose which PORT and pin controls the solenoid
PORTB.F0 = 1;
void SendMessage(){
UART_init(9600);
UART_Write_Text("AT+CMGS="); //AT+CMGS=
Delay_ms(1000);
UART_Write(0x22); //"
Delay_ms(2000);
UART_Write_Text("0060179291471"); // my no
Delay_ms(2000);
UART_Write(0x22);
UART_Write(0x0D); //(CR) means Enter
Delay_ms(2000);
UART_Write_Text("PLG Leak Concentration > 10ppm"); // my text
Delay_ms(2000);
UART_Write(26); // Ctrl z
Delay_ms(2000);
Delay_ms(2000);
