programming for PIC 16F877a
Rooney_04
Member level 2
hi
I m using C compiler for programming the 16f877a. I would like send binary data through this PIC by using RS 232 communication which able to transmit data serially. I would to program like i have a push button connected to PIC. When a press the push button, the pic will send certain binary data(8bit).So i hope the members would give suggestion or idea or perhaps some example of programming regarding this topic. Actually i m kind of desperate for this solution...lol
Tahmid
Advanced Member level 5
Silicon Valley, California, USA (from Dhaka, Bangl
For this purpose you have to use USART/UART module incorporated in the controller. Check the relevant section in the datasheet. If you are using mikroC or mikroBASIC, in the help file, there is an example of using UART and in the examples, there are a few examples, as well as in the manual. What compiler are you using?
Hope this helps.
Tahmid.
Rooney_04
Member level 2
Me using CSS C compiler. So can u help?
furthemore i m planning using this command
"#use rs232 (baud=2400, xmit=PIN_C6, rcv=PIN_C7)"
pmar_kpj
Member level 3
Romania
hi !
if you use CCS C compiler try to find this example : Ex_sisr.c .
this example shows how to use serial interrupt.
