Programming 328P with XPLAINED Mini
After removing the onboard ATmega328 or cutting some of its ISP traces.
You did not specify what toolset you are using to compile/develop your program, but if it were Arduino (which I assume being not the case), you could write the "Arduino as ISP" demo code that allows you to turn an Arduino board into a programmer to a second board.
I don't have an Arduino. If I were to remove resistors R110-R113 on the XPLAINED mini board, would I be able to connect the signals to the relevant pins on the IC I am trying to program on it's own PCB? Is power also required in addition to the ISP signals to program?
This is not a serious question, is it?
Electronics without power does not work.
In doubt consult the datasheet.
Klaus
Klaus
What I meant is whether power to the IC to be programmed would be supplied via the programmer. It seems that if I were using the XPLAINED mini board, I would need to supply power separately.
If you wire VCC, then the target will be supplied.
But for sure it has limited power drive capability. For a single IC this would be OK, but nobody knows how much your whole application draws.
Klaus
