Programmer for Philips LPC2131 & TI TMS470
aetosa
Member level 3
tms470 programmer
I'm looking for a schematic for 2 simple programmers for 2 ARM7 uP: Philips LPC2131 and Texas Intstuments TMS470. Do you know something about them?
Thank you in advance for helping me.[/b]
wiggler 74hc244
This is a JTAG for most ARM controllers
a similar can be bought here:
www.olimex.com (they have great development boards too!)
Antharax
lpc2131
h**p://www.siwawi.arubi.uni-kl.de/avr_projects/arm_projects/wiggler1.pdf
Antharax
This version of wiggler do not working with latest Macraigor software and drivers .....
programator tms470
Thank you all for your help and concern. How about software? What can I use?
tms 470 arm 7
Any link to a new/working version?
Or does someone know if the olimex jtag works for them?
74ac244 replacement
It is simple :)
If you get "Internal Error 43", you must connect pins 15 & 8 on LPT port DB25 connector.
crossworks olimex tms470
Well? Does anyone know what software should I use with this wiggler? Also, pins 15 7 8 of ARM to which pins of DB25?
Added after 18 seconds:
Well? Does anyone know what software should I use with this wiggler? Also, pins 15 & 8 of ARM to which pins of DB25?
lpt 74hc244 schema
1. For example, CrossWorks.
2. Pin 15 to pin 8 on LPT side. It has nothing related to ARM pins and used by software to detect cable presence.
tms470 jtag
Hey all ! In Wigler Jtag schematic , can I replace 74AC244 and 74LC244 by 74HC244, does it work OK ??
wiggler +arm+pdf+programer
Problem is that 74LC244 is with 5V input tolerance when power supply is 3.3V, but
74HC244 do not have 5V input tolerance. I buld Wiggler with one 74HC244 chip,
that powered from JTAG, with 100R rezistors in 74HC244 inputs from LPT interface.
программатор tms470
I also have some more general questions. ARM7 is low power architecture, while ARM9 is the 'normal' one, and with better perfomance?Is that so?
I recieved some samples TMS470 from TI, but they are 'tiny...'. ARM9 has normal dimensions? Does TI diliver samples ARM9?
74hc244 arm jtag
Does anybody have a pcb for wiggler programmer?
