programmer ckt for 8051/52
alvarorahul
Full Member level 1
hey guys
i wanted to know if neone has a simple 8051/52 programmer ckt
the ones i found through search engines seem to be quite complicated
if neone has ne simple one which can be done easily then pls post it
Hai
I havent seen a simple pgrmr for 8051 old types.
Which is the make you are using?
If 89S51/52 available in your area you can locate a simple prgrmr for that.
As far as I know all programmers for 89C51 requires substantial hardware for address and other decoding.
picstudent
HI
Have you heard of ponyprog ? The hardware is simple to make (uses 74HC244) and as far as I remember it can program some ATMEL 8051 like AT89S53 / AT89C8252.
Please download the software and see the uC options in the GUI.
If not than you must buy dedicated 8051 programmer which are available on the internet.
Thanks
u want programmer for 89c2051 or 89c51 or 89s51
they all diffr man
