Programmable ROM in ASIC
kevinj
I'm using Verilog to create an ASIC and then later using Encounter to synthesize the design. In Verilog I use a Block ROM to store some coefficients, however for the ASIC I would like to stream in the coefficients as those values change from one ASIC to the other. I'm thinking about using some sort of SPI interface. Is there a simple way of achieving this? Or how would I go about doing this? I'm targeting this design for UMC 90nm.
Thanks
FvM
Super Moderator
Staff member
Bochum, Germany
I think so.
Connecting all parameter bit registers to a chain would be basically sufficient to load parameters. A second register set to latch the data from shift register would extent the interface to standars SPI and also allow parameter reload during operation.
kevinj
Thanks for the reply. Is there any way to have the data be stored indefinitely, something along the lines of an internal EEPROM? Or do I need to have an external EEPROM and have the ASIC read in the values to the registers during bootup?
Thanks
FvM
Super Moderator
Staff member
Bochum, Germany
I wouldn't expect EEPROM cells in an usual ASIC process.
