Register Log in
Program for converting the gerber files to PowerPCB files?
ruggine
Junior Member level 3
camtastic bmp import
hi
does someone know a program to convert the files gerber to file powerpcb?
cancel
Full Member level 5
gerber to pcb
i have not seen that .. i have seen utility to convert bmp (bitmap) to protel file .. but it could be way fory you .. just save gerber as bmp (layer by layer)
and convert .. maybe you can import protel file ;0))
mrcube_ns
Advanced Member level 1
Europe
Re: gerber to pcb
If I'm right PCAD's Camtastic can do that.
Mr.Cube
binu G
Advanced Member level 2
Bangalore
gerber to pcb
gerber to powerpcb is possible but u will lose some paramters durring conversion process
u can use cam350 for conversion by creating netlist and so on....
but it is not a good suggection since chances of hidded error
binu
rishabkailas
Member level 1
Re: gerber to pcb
If you want any of layer as a reference for routing . you can convert ther gerbr in to dxf using"GerbTool" and can import as dxf.
rishab
binu G
Bangalore
gerber to pcb
mr . rishabkailas do u think that u can edit the dxf file in the powerpcb any logic is imported with dxf.
try
binu george
Frosty
Full Member level 6
EARTH
Re: gerber to pcb
Most CAM tools capable of grouping objects to create parts can do this.
First you load gerbers & drill
Define parts etc
Then extract netlist
For Power PCB you would be best to use a Gerber editor which will export a native PPCB file such as Cam350 from Downstream.
You will not find any free veiwer I know of that will do this easily.
hcet
Full Member level 5
Re: gerber to pcb
i would like to import a gerber design into eagle. has anybody done this with success?
hcet
Full Member level 5
Re: gerber to pcb
hi sinanweb,
can you tell me how you convert a gerber-file to eagle with isopro?
greez, ep20k.
Toggle Sidebar
