how can i program atmega 32 microcontroller interfaced with zigbee so that sensors information from transmitter goes to receiver side.
chk this .it is the programme to control a robot using zigbee from pc.P89v51rd2 is used.
#include <intrins.h>
#include "p89v51rx2.H"
sbit buzzer = P2^7; //Buzzer pin
sbit LB=P1^0; //LEFT BACK Pin
sbit LF=P1^1; //LEFT FRONT Pin
sbit RF=P1^2; //RIGHT FRONT Pin
sbit RB=P3^4; //RIGHT BACK Pin
sbit left_velocity=P1^3; //Left velocity control pin.
sbit right_velocity=P1^4; //Right velocity control pin.
sbit start_conv = P3^6; //P3^6 is connected to Start and ALE pin of ADC0808
sbit output_enable = P3^7; //P3^7 is connected to Output Enable Pin of ADC0808
unsigned char front_sharp_sensor = 0; //used in stop n go ACC
// function for giving a delay of ms milliseconds
void delay_ms(unsigned int ms)
unsigned int i,j;
for(i=0;i<ms;i++)
for(j=0;j<53;j++);
}//end of delay_ms
unsigned char ADC_conversion(unsigned char ADC_ch_no)
unsigned char ADC_data;
P0 = ADC_ch_no; // to select channel no. send address on P0
start_conv = 1; // ADC0808 will latch the address on L-H transition on the ALE pin
start_conv = 0; // ADC0808 will start conversion on H-L transition on the start pin
delay_ms(2); // conversion time for ADC0808
P0 =0xFF; // output enable and read
output_enable = 1; //Enabling o/p of ADC0808 for to read the converted data
ADC_data = P0; //storing adc_data
output_enable = 0; //disabling ADC 0808 o/p
return ADC_data; //returning adc_data
RF = RIGHT MOTOR FORWARD
RB = RIGHT MOTOR BACKWARD
LF = LEFT MOTOR FORWARD
LB = LEFT MOTOR BACKWARD
//direction control subroutines
void forward(void)
RF=1;
LF=1;
RB=0;
LB=0;
}//end of forward
void backward(void)
RF=0;
LF=0;
RB=1;
LB=1;
}//end of backward
void left(void)
RF=1;
LF=0;
RB=0;
LB=0;
}//end of Left
void right(void)
RF=0;
LF=1;
RB=0;
LB=0;
}//end of Right
void stop(void)
RF=0;
LF=0;
RB=0;
LB=0;
}//end of Stop
Function: uart_setup()
Description: This function configures Timer1 for generating the Baudrate.
The TH1 register should be written with following hex numbers
for desired baud rate. After setting the baudrate, SCON register
for enabling Rx and setting up the frame format.
9600 -----> 0xFD
4800 -----> 0xFA
2400 -----> 0xF4
1200 -----> 0xE8
void uart_setup()
TMOD = 0x20; // configure timer1 for Mode 2 operation for the correct baud rate
TH1 = 0xFD; // 9600 bps for 11.0592 MHz clock
TCON = 0x40; // Start timer 1 by setting TR1 = 1
SCON = 0x50; // Set Serial IO to receive and normal mode
RI=0; //Receive Interrupt Flag is cleared
TI=0; //Tx interrupt flag is cleared
}//end of uart_setup
Function: void char RxData()
Description: This function copies any data that is present in the SBUF
register and returns it to the calling function.
unsigned char RxData()
unsigned char rcv_data;
rcv_data = SBUF; //if any data is available copy it from SBUF
return rcv_data; //return the received data
}//end of RxDAta
//main function
void main(void)
unsigned char rx_data;
buzzer=1;
left_velocity=1; //setting this pin to one sets the motor to run at maximum velocity.
//Thus enable pin of Motor driver is always on unlike in PWM mode.
right_velocity=1; //setting this pin to one sets the motor to run at maximum velocity.
uart_setup(); // calling the UART setup function
while(1) //loop continuously
front_sharp_sensor = ADC_conversion(2);
if (RI==1) // if any data is present store it and transmit it back
rx_data = RxData(); //get the received data
if(rx_data == 'F'){ //move robot fprward
forward();
RI = 0;
TI = 0;
if(rx_data == 'B'){ //move robot backward
backward();
RI = 0;
TI = 0;
if(rx_data == 'L'){ //move robot to left
stop();
left();
delay_ms(500);
stop();
RI = 0;
TI = 0;
if(rx_data == 'R'){ //move robot to right
stop();
right();
delay_ms(500);
stop();
RI = 0;
TI = 0;
if(rx_data == 'S'){ //move robot to right
stop();
RI = 0;
TI = 0;
if(rx_data == 'O'){ //switchon buzzer
buzzer=0;
RI = 0;
TI = 0;
if(rx_data == 'N'){ //switch off buzzer
buzzer=1;
RI = 0;
TI = 0;
RI = 0;
TI = 0; //Clear receive interrupt. Must be cleared by the user.
if(front_sharp_sensor >= 110) // obstacle is near the robot, stop and turn on the buzzer
stop();
backward();
left();
delay_ms(500);
stop();
//buzzer=0;
}//end of main
