Process Variation simulation
nile_king
Member level 1
Egypt
Hi
Dear All;
I wanna ask how to simulate the process variation for ref current using cadence and i have no licence for monte carlo
in changeing the models of the transistors, res, BJT, ... in the model library, change it to what??
thanks
cristianb
Member level 1
use corner models in you simulation. you can do this by seleting from ADE SETUP->model libraries an here select the corner switch.
nile_king
Member level 1
Egypt
Thank you for ur help
I also need to know what 2 write
for example i know the model changes for CMOS and BJT
what about the res and cap ...
thanks
maxwellequ
Full Member level 3
The corner models for the transistors are provided by the foundry.
For resistors/capacitors in most cases either there are models from the foundry or there is documentation stating the variations. In case you do not have this info, you may use +/- 20 % to +/- 25 % of absolute value variation (typical range).
dog1357
Member level 3
in mentographics, u may use some script to change all the resisitor and capacitor value at one time, not sure candence get this or not.
cristianb
Member level 1
according to the technology switch you select all device models will be altered. the name of the switch differs from foundry to foundry. Usually these are:
ff-> fast
ss-> slow
fs->fast slow
sf-. slow fast
You show find in the technology forder a file that contain an index of the models used in that technology and there these switches should be specified.
    nile_king
