Procedure for installing Cadence ICFB on Linux 5.0
dipak.rf
Member level 3
Can anyone tell me the step by step procedure to install cadence icfb under linux 5.0?
Documents will be ok or any link for document.
Cesar92
Newbie level 6
cadence_aptivia33_lnx86
Hello,
you can use this installation of Cadence 5033 under Mandriva Linux 9.2 or others operating system Linux.
1. Installation of Cadence IC 5.0.33 (Virtuoso/Spectre/Dracula)
-Start a console (Konsole under KDE)
-Logging as root:
> su -
Password:> (enter the root password here)
-Create the InstallCadence directory in your personal home directory:
> mkdir /home/thedock/CadenceInstall/
-Copy all the content of the Cadence DVD to the following directory: /home/thedock/CadenceInstall/
> cp -r /mnt/cdrom/* /home/thedock/CadenceInstall/
Note: you can also use you favorite file manager under KDE to make these two previous steps.
Note: this step is necessary because the Cadence installation program is extremely sensitive to read errors on the CDROM for example.
-From now on, you will have the following directories:
/home/thedock/CadenceInstall/VSDE33/
/home/thedock/CadenceInstall/IC5033/
/home/thedock/CadenceInstall/Hacker/
/home/thedock/CadenceInstall/InstallCadence_extrafiles/
-Delete the previous Cadence folder if it exists:
> rm -fr /Cadence
-Go into the following directory: /home/thedock/CadenceInstall/IC5033/ISR200406181244/CDROM1/
>cd /home/thedock/CadenceInstall/IC5033/ISR200406181244/CDROM1/
-Execute the installation script from this directory (be carefull with the capitals):
> ./SETUP.SH
-Specify path of install directory [OR type [RETURN] to exit]:
> /Cadence
-Directory /Cadence does not exist. Create? [y/n]:
> y
-Do you want to start softload? [y/n]:
> y
-Warning: Software administration should not be done as root because it could cause file permissions problems while extracting software Press [Return] to proceed, q to quit :
> (just press RETURN to accept to continue)
-The available options are:
> 1 (Load Available Products)
-You must now identify where the CD-ROM is mounted:
> 1 (Local (mounted to this machine))
-Specify the CD-ROM mount point:
> 2 (Other)
-Type the CD-ROM mount point: [ /home/thedock/CadenceInstall/Cadence_Virtuoso_IC5033_lnx86/ISR200406181244/CDROM1 ]
> (just press RETURN to accept to continue: the path should be correct at this point)
-Do you want to view the README file? Please press y (yes) or n (no) :
> y
-Follow the standard Cadence installation instructions. Press [Return] to proceed, q to quit :
-Where is the installation information?
> 4 (Cadence Catalog)
-311:Unknown Product Name Removed from QSR. Press [RETURN] to continue:
-Go to the end of the products list by pressing the SPACE BAR
-Type your choice (a,n,p,1-3,2 5 9 ...):
> a (All of the above)
-Go to the end of the list of the selected products by pressing the SPACE BAR
-Are your selections correct? [y/n]
> y
-Disk checks successful. The following products will be installed or updated. Just press SPACE BAR to continue.
-The following media is required:
IC5033 lnx86 P/N 356-70352-0301 CDROM # 1
IC5033 lnx86 P/N 356-70352-0302 CDROM # 2
IC5033 lnx86 P/N 356-70352-0303 CDROM # 3
IC5033 lnx86 ISR 200406181244 CDROM # 1
IC5033 lnx86 ISR 200406181244 CDROM # 2
IC5033 lnx86 ISR 200406181244 CDROM # 3
-Wait until the next CDROM is asked for (~7 minutes)
-Your package selections require IC5033 lnx86 P/N 356-70352-0301 CDROM # 1.
> 4 (Change CD-ROM mount point.)
-You must now identify where the CD-ROM is mounted.
> 2 (Other)
-Type the CD-ROM mount point: [ /home/thedock/CadenceInstall/IC5033/ISR200406181244/CDROM1 ]
> /home/thedock/CadenceInstall/IC5033/Base/CDROM1
-CDROM # 2 and CDROM # 3 will be loaded automaticaly. There is nothing to do, just wait.
-Verify your installation. The available options are:
> 2 (List Installed Products)
-Specify the operating system of the products:
> 3 (lnx86)
-Now you can quit the Cadence IC 5.0.33 installation and begin the Aptivia installation. The available options are:
> q (Quit)
2. Installation of Cadence Aptivia
-Before you try to install Cadence Aptivia, you must have installed all the Cadence IC 5.0.33 products.
-Go to the following directory: cd /home/thedock/CadenceInstall/VSDE33/ISR200406301301/CDROM1/
-Make sure you are also logged in as root:
> su -
> ./SETUP.SH
> /Cadence/APTIVIA33
-Directory /Cadence/Aptivia does not exist. Create? [y/n]:
> y
> y
> 2 (Other)
-Type the CD-ROM mount point: [ /home/thedock/CadenceInstall/Cadence_Aptivia33_lnx86/Base/CDROM1 ]
> y
Aptivia 3.3 (for use with IC 5.0.33, IC 5.0.32, or IC 4.4.6 MSR 11 or later)
The following environment variable must be set to the installed location
of the Aptivia software:
setenv ACV_ROOT <path>/tools/acv
where <path> is the directory where the Aptivia software was installed.
The Aptivia bin directory must be appended to the path variable as follows:
set path=( $path $ACV_ROOT/bin)
Documentation is available on SourceLink. HTML versions of the manuals are
additionally installed in the following locations:
Aptivia User's Guide $ACV_ROOT/docs/acvug
Aptivia Reference Manual $ACV_ROOT/docs/acvrm
Aptivia Optimization User's
Guide $ACV_ROOT/docs/optug
DCM User's Guide $ACV_ROOT/docs/dcmug
MATLAB Measures User's Guide $ACV_ROOT/docs/matlabmeasug
-Press [Return] to proceed, q to quit :
> 4 (Cadence Catalog)
> y
VSDE33 lnx86 P/N 356-73091-0301 CDROM # 1
VSDE33 lnx86 ISR 200406301301 CDROM # 1
-Your package selections require VSDE33 lnx86 P/N 356-73091-0301 CDROM # 1.
> 2 (Other)
-Type the CD-ROM mount point: [ /home/thedock/CadenceInstall/VSDE33/ISR200406301301/CDROM1 ]
> /home/thedock/CadenceInstall/VSDE33/Base/CDROM1
> 3 (lnx86)
-Now you can quit the Cadence Aptivia installation and begin the Hacker Script installation. The available options are:
> q (Quit)
3. Installation of the Hacker Script
-When the installations of Cadence IC 5.0.33 and Aptivia was successfull, you can enter the Hacker Script installation.
> su -
-Copy the Hacker Script and data file to the following directory /Cadence/:
> cp /home/thedock/CadenceInstall/Hacker/* /Cadence/IC5033/
-Go into the following directory /Cadence/IC5033
> cd /Cadence/IC5033
-Build symbolic link to the Cadence files (au lieu d'un lien direct):
> ln -s /Cadence/IC5033/tools.lnx86 /Cadence/IC5033/tools
> ln -s /Cadence/VSDE33/tools.lnx86 /Cadence/VSDE33/tools
-Run the Hacker Script:
> ./hacker hacker.script > /dev/tty (be carefull: the second ">" in this line is not a prompt: it is the mathematical symbol)
-Normally, a few errors should occur (5~6), but a lot of files should be scanned and some of their will be modified.
4. Installing Netscape 7.1 for Cadence Documentation viewing
-Since I found no solution to use Mozilla for documentation viewing in Cadence, here is the description how to install and configure Netscape for using it to view the Cadence Docimentation
-Open a Console (Konsole)
> su -
-Goto the following directory /home/thedock/CadenceInstall/Netscape
> cd /home/thedock/CadenceInstall/netscape-i686-pc-linux-gnu-sea/
> ./netscape-installer
-A new window will pop-up: click "Next"
-Continue by clicking "Accept"
-Select "Full" but let the default installation directory (/usr/local/netscape)
-Click "Next" to continue
-Click "Install" to make the Netscape installation
-Click "OK" when installation has completed: now Netscape is installed into /usr/local/netscape/
-Go to the directory in which the RealPlayer RMP is located:
> cd /home/thedock/CadenceInstall/RealPlayer
-Launch the installation of the RealPlayer RPM:
> rpm -i rp8.linux20.libc6.i386.cs2.rpm --nodeps --force
-A new window will open. Click on "Finished"
-Click on "OK"
-Enter you Email, deselect "inform me on updates and events" and click "Next"
-Select you connection speed and click "Finished": RealPlayer is now installed
5. Configuration of the Environement Variables
-After you applied the Hacker Script successfully, you must configure the environement variables
-Now goto your following directory: /home/thedock/
-Edit the .bashrc file: /home/thedock/.bashrc (for bash users only, the others will not be described, but take a look at the end if you are using ksh or compatible)
-Add the environement that follows:
export ACV_ROOT="/Cadence/VSDE33/tools/acv"
export LANG C
PATH=$PATH:/usr/local/netscape:/Cadence:/Cadence/IC5033:/Cadence/IC5033/tools:/Cadence/IC5033/tools/dfII:/Cadence/IC5033/tools/dfII/bin:/Cadence/IC5033/tools/bin:$ACV_ROOT/bin
-If you do not use bash (csh for example), you will need to use following syntax:
setenv ACV_ROOT /Cadence/VSDE33/tools/acv
setenv LANG C
set path = ($path /usr/local/netscape /Cadence /Cadence/tools /Cadence/tools/dfII /Cadence/tools/dfII/bin /Cadence/tools/bin $ACV_ROOT/bin)
-The variables for other shells can also be found in the following directory: /home/thedock/CadenceInstall/InstallCadence_extrafiles/envvariables)
-Reboot you computer
-Open a Console (Konsole for example)
-To start Cadence, type:
> icfb &
-And now, Cadence will start!
-To start the documentation, type:
> cdsdoc &
good luck
