[SOLVED] Problems with using string compare functions of string.h
sherazi
Banned
Muscat, Oman, Oman
i am getting errors for using string compare functions of string.h
char m1[9]="00000000\0";
unsigned char numb[9]="00000000\0";
if (strncmp(m1,numb1,8)==0)
i get this error
Error	8	expected 'const char *' but argument is of type 'unsigned char *'
how can i solve this, I am using avrstudio5 and my target is Atmega644
Re: problems with stncmp
The compiler error indicates it expects a "const char *" and doesn't seem to like the "unsigned" type specifier.
Have you tried removing the type specifier "unsigned" :
original
rewritten
Also in the call to the strncmp(), you have:
shouldn't numb1 be numb
if (strncmp(m1,numb,8)==0)
The compiler didn't seem to complain about m1, so try removing the "unsigned"
And if all else fails, you can always cast
if (strncmp(m1,(const char *)numb,8)==0)
Try these suggestions and let me know the results.
thanks .
replacing
unsigned char numb1[9]
with
char numb1[9]
solved the issue.
regarding numb and numb1 issue ,that was a typing error its numb1 everywhere
