hafrse
Full Member level 3
Hello,
I have an Otari R2R tape recorder and had problems with the +5V regulated power supply (around 10A) where it passed through 9.1V to the control circuit electronics and burned the EPROM (27256) + other IC:s.
Attached an image of the power supply :
Q1,Q2 is a 2SA1020 transistors.
IC-1 is a M5231L regulator.
On of the 2 2SA1020 was shorted which caused a voltage of 9.1V and replaced , now the power supply is ok.
My question is, how can I build an overvoltage protection like above +6V the the +5V supply will be shorted and the built in automatic fuse in the recorder will disengage because of the short ? I was thinking to add a zener diode but could not find with high current support (?) ?
Thanks
Thanks
