Problems when attempt to write in real time a data to 25L080 SPI memory but not in si
johnnystrong
I use PIC16F84A to write to 25L080 memory it successfully wok in simulation time but not at a time
After sending, data when I read 25L080 status register it give B’0000 0010’ which mean that, write allowed but not write in progress. What can be the problem?
Please I needed your help
here is diagram circuit
  • 25L080.pdf
Hello there,
How do you reading it back.
Try these..
1.SEND read command
2.send dummy byte
3.read SPIBUF
Best regards,
Code ASM - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
67
68
69
70
71
72
73
74
75
76
77
78
79
80
81
82
83
84
85
86
87
88
89
90
91
92
93
94
95
96
97
98
99
100
101
102
103
; write into one page
PAGE_WRITE1
                                CALL                    WRITE_ENABLE1      ;send write enable
                                BCF             CS1                     ;enable eeprom
                                MOVLW           0X02                    ;send write opcode
                                CALL            SHOUT1
                                MOVF            ADRH1,W
                                CALL            SHOUT1                  ;send MSB adress byte
                                MOVF            ADRH0,W
                                CALL            SHOUT1                  ;send LSB adress byte
                                MOVLW           0X55                    ;0X55 is data to be transmit
                                CALL            SHOUT1
                                BSF                     CS1             ; disable eeprom
                                CALL            TEMPOB                  ;wait for signal CS1 stability
                                CALL            READ_STATREG1           ;read state reg
                                MOVWF           SCREEN                  ; print at portb
                                MOVLW           0X18         ; wait for write complete and for me to read portB
                                CALL            TEMPO
                                CALL            READ_STATREG1
                                MOVWF           SCREEN          ; read status reg after write complete
                                RETURN
that is part of code which write data to eeprom memory and test if write is in process.
 i send dmmy byte when i call SHIN function.
i did all these functions by myself because i use PIC16F84A
; read eeprom status reg
READ_STATREG1
                                BCF                     CS1             ; enable eeprom
                                MOVLW           0X05                    ; send read state reg opcode
                                CALL            SHOUT1
                                CALL            SHIN1                  ; i send dummy byte here
                                BSF                     CS1
                                RETURN
[COLOR="silver"][SIZE=1]- - - Updated - - -[/SIZE][/COLOR]
PAGE_WRITE1
                                CALL            SHOUT1
                                MOVF            ADRH1,W
                                MOVF            ADRH0,W
                                CALL            SHOUT1
                                CALL            TEMPO
                                CALL            READ_STATREG1
                                RETURN
READ_STATREG1
                                CALL            SHOUT1
                                BSF                     CS1
                                RETURN
is anyone have a suggestion for me about my problem? is the fact that PIC16F84a is TTL output and input may cause this effect? because 25L080 is cmos technology.
